Random air cooled question, Weird behavior after oil change |
Jett |
Nov 23 2023, 05:54 PM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
… this is not about a 914 but is about our 1977 911S Targa 2.7L
Took her in to have a bad ground fixed that was blowing a fuse on the clock/lighter circuit. While being serviced we had an oil change done although it didn’t really need it. We had 10L’s of Motul 20/50 added and new filter. While driving home I noticed that the oil pressure during throttle was almost pinned. When we got home (2 miles) the oil reading on the gauge at rest on level ground was just above the low line. This morning we moved it on the lift for winter storage and noticed a small puddle of oil, which never happens with this car. I cleaned the undercarriage and will see in the morning. Any ideas? |
Bullethead |
Nov 23 2023, 06:58 PM
Oil Cooled heart Group: Members Posts: 897 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
Was the oil level checked with engine warm, thermostat open, idling on level ground? Ten liters including filter? Is the engine stock?
FWIW, I have a '67 911S and a '68 T and both show nearly zip oil pressure at idle when warm, but pressure rises appropriate to RPMs. |
Jett |
Nov 23 2023, 08:11 PM
Was the oil level checked with engine warm, thermostat open, idling on level ground? Ten liters including filter? Is the engine stock? FWIW, I have a '67 911S and a '68 T and both show nearly zip oil pressure at idle when warm, but pressure rises appropriate to RPMs. Yeah oil pressure rises during throttle but not pinning the gauge. When measuring oil it was warm, at idle, and flat ground. Not sure how modified the 2.7 is but appears stock configuration. |
Root_Werks |
Nov 23 2023, 08:18 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
20/50 seems pretty thick.
There are 1,000+ threads and opinions on oil. Do some research and change out the oil. My guess is pressure will return to normal with something a little lighter. |
bkrantz |
Nov 23 2023, 08:25 PM
914 Guru Group: Members Posts: 7,804 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
20/50 seems pretty thick. There are 1,000+ threads and opinions on oil. Do some research and change out the oil. My guess is pressure will return to normal with something a little lighter. Especially for winter season. It might take a long time for that oil to really get hot (and thin). |
Krieger |
Nov 23 2023, 09:09 PM
Advanced Member Group: Members Posts: 4,728 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I am wondering what they did to fix the ground on the clock. I think (not 100%) if you ground the oil pressure sender out (or the wire from the sender to the gage) it pins the gauge. Take it back in.
Jett |
Nov 23 2023, 10:23 PM
I am wondering what they did to fix the ground on the clock. I think (not 100%) if you ground the oil pressure sender out (or the wire from the sender to the gage) it pins the gauge. Take it back in. My mechanic is coming over on Tuesday. The oil pressure goes down at idle but up at throttle , so the wiring should be ok. The engine had 20/50 in it before but the temps havee changed. … oil on the ground was overflow and/or blow off? |
falcor75 |
Nov 23 2023, 11:10 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
The small puddle could it be spilled oil from the refill that made its way onto the ground overnight?
mlindner |
Nov 24 2023, 06:27 AM
Senior Member Group: Members Posts: 1,529 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
20/50 is the oil of choice on these older flat six engines.
rgalla9146 |
Nov 24 2023, 07:17 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
20/50 is the oil of choice on these older flat six engines. I agree. Oil pressure light 'on' at idle is common as well. Where under the engine ? front, rear, left or right ? Could be spilled oil from the filter removal dripping from the engine tin. Also, 10.5 qts. seems a bit high on an oil change. You're doing the right thing. Better to be cautious. |
Jett |
Nov 24 2023, 11:20 AM
20/50 is the oil of choice on these older flat six engines. I agree. Oil pressure light 'on' at idle is common as well. Where under the engine ? front, rear, left or right ? Could be spilled oil from the filter removal dripping from the engine tin. Also, 10.5 qts. seems a bit high on an oil change. You're doing the right thing. Better to be cautious. Thanks! The oil was under the drain plug area and I see no signs of a higher up drip. No oil this morning, but the car has not been started. My mechanic is an amazing practitioner and did the wiring fix, but probably had one of his helpers do the oil change. Regarding the oil amount, I am only referencing the bill that stated 10L of 20/50. Thanks for all of the comments. |
Jett |
Dec 1 2023, 06:38 PM
Turned out to be what some suspected…
1. Oil on ground caused by spillage during change. 2. Oil pressure increase was old oil versus new 20/50 + temp outside is cold. 3. Oil level was fine once we let the car sit to get up to temp (180 degrees). |
930cabman |
Dec 2 2023, 07:41 AM
Advanced Member Group: Members Posts: 3,148 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
All is well that ends well, your mechanic needs a different funnel
Jett |
Dec 2 2023, 08:51 AM
arbitrary |
Dec 2 2023, 12:31 PM
Member Group: Members Posts: 81 Joined: 25-April 21 From: UK Member No.: 25,475 Region Association: None |
Make sure your gauge reading matches the dipstick reading….
porschetub |
Dec 2 2023, 01:40 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Lo-Fi Version | Time is now: 10th June 2024 - 07:17 AM |
