Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,016 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
I bought a set of the plastic expanding "push" rivets from 914rubber - and they're a bit of a nightmare TBH. Their pins are wayyy too tight as they come, and my install ratio keep decreasing. Pins will not turn by hand or otherwise, and mostly just end up breaking when trying to tap them in. Anyone got suggestions for working with these?
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 735 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
Try Grainger Supply for black plastic rivets.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,737 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I bought a set of the plastic expanding "push" rivets from 914rubber - and they're a bit of a nightmare TBH. Their pins are wayyy too tight as they come, and my install ratio keep decreasing. Pins will not turn by hand or otherwise, and mostly just end up breaking when trying to tap them in. Anyone got suggestions for working with these? . Thx for the warning. I bought a set and if the 1st one gives me a difficult time I'll send the lot back. |
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,350 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
Just drill them clear
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
A little disturbing from my viewpoint.
I have a set coming... I'll report what I find. Maybe a bit of heat could help? I'm guessing you tried lubricants? Super clean the holes out.? |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,368 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
I recently bought a set from 914 and they were very soft plastic and there was no way I could insert them. Found some in McMaster that will work but will require slightly larger holes.
The McMaster ones are very close dimensionally and in appearance to the original just slighty larger. |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,688 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
just use metal rivets, many sizes and also in black.
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,012 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Mark is going to want to know about this.
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,167 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
Here’s what I do :
clip the rod very close to the rivet head. Trim the cut end just a bit with a utility knife. Insert the rivet into the whole. Slip the trimmed end of the rod into the rivet head hole. Tap the rod into the rivet head. A bit of a work-around, but works! |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,742 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Here’s what I do : clip the rod very close to the rivet head. Trim the cut end just a bit with a utility knife. Insert the rivet into the whole. Slip the trimmed end of the rod into the rivet head hole. Tap the rod into the rivet head. A bit of a work-around, but works! (IMG:style_emoticons/default/agree.gif) But cleaned the hole by hand with a small drill bit in a pin vise, then insert into rivet and tap down. |
Nate W |
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-February 21 From: Oceanside, Ca Member No.: 25,250 Region Association: Southern California ![]() ![]() |
I insert the plastic rivet, holding the pin with some small needle nose pliers, then gently tap with a tiny hammer to get them started / broken free without bending the pins
Literati914 |
.. Super clean the holes out.? I could get the rivets in the holes just fine, the soft flimsy pins though will mostly give before they'd move and not move at all. They're too tight leaving you with a destroyed rivet. And that's tapping very gently with a smallish cobbler's hammer (learned after the first one that soft coaxing would be needed). I was successful on two of the six that I tried. Hopefully you guys have better luck! I recently bought a set from 914 and they were very soft plastic and there was no way I could insert them. Found some in McMaster that will work but will require slightly larger holes. The McMaster ones are very close dimensionally and in appearance to the original just slighty larger. I'm gonna look over there - Thanks! |
Literati914 |
Here’s what I do : clip the rod very close to the rivet head. Trim the cut end just a bit with a utility knife. Insert the rivet into the whole. Slip the trimmed end of the rod into the rivet head hole. Tap the rod into the rivet head. A bit of a work-around, but works! Thanks SB, but I'm afraid that would be impossible with the set I have, as getting the pin out in the first place would destroy one or both parts of the rivet. . |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The way to install these is not intuitive.
Snap off the pun, fluo it over and push it into the rivet section. Its pretty easy if you do it this way. I have never been able to tap it straight in, its allways slighty off, starting it manually is the only way to go.. |
87m491 |
Member ![]() ![]() Group: Members Posts: 330 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States ![]() ![]() |
The way to install these is not intuitive. Snap off the pun, fluo[b][u] it over and push it into the rivet section. Its pretty easy if you do it this way. I have never been able to tap it straight in, its allways slighty off, starting it manually is the only way to go.. Where's autocorrect when you need it? Gotta ask as my 914R rivets have been waiting for my threshold trim to arrive. Are you saying insert the pins into the bottom of the rivet before then inserting the rivet into the hole? (assumed that you insert far enough so some sticks out the top and then will be tapped down for final fitment? |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
the aftermarket ones are too big, only the factory ones fit, NO ONE wants to enlarge the holes these days anyway. buy factory rivets tear off the attached peg, put the rivet in the hole, open the rivet a bit to accept the peg and then tap home with a flat body hammer
I bought a set of the plastic expanding "push" rivets from 914rubber - and they're a bit of a nightmare TBH. Their pins are wayyy too tight as they come, and my install ratio keep decreasing. Pins will not turn by hand or otherwise, and mostly just end up breaking when trying to tap them in. Anyone got suggestions for working with these? . |
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,380 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
Are the rivets metric? I never checked. Are they available anywhere? I ran into this with some sheet metals screws. Never occurred to me to look for metric ones.
TonyA |
Nachmal ![]() ![]() ![]() Group: Members Posts: 614 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States ![]() ![]() |
What color should they be. Clear plastic or black?
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,857 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
Why would a German car have non-metric fasteners? (IMG:style_emoticons/default/smile.gif)
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,777 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
What color should they be. Clear plastic or black? Picture for color refrence only. Sourced from early cars for years. Not clear, not white either. Black came '73 ? Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 11th July 2025 - 05:21 PM |
