qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
I may just power wash this stuff, will anthing cut it?
Attached image(s) ![]() |
spare time toys |
hooked on grilling food. ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region ![]() |
lacker thinner and scotch brite pads. its how i cleaned mine.
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
I use denatured alcohol for a lot of my cleaning. It is inexpensive and easy to work with. It should cut through that no sweat.
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
"Carburetor Cleaner", in the large 5-gallon drums at Kragen for $60. Don't get any on you -- it's so strong it can rend the flesh from your bones.
joeav8tor |
Member ![]() ![]() Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 ![]() |
I used about 20 cans of brake cleaner....place a ton of newspaper underneath the heads or motor and tranny...the brake fluid eventually evaporates and then you can throw out the paper without making a mess of your garage floor....I bought it by the can because I did not realize that I was going to be going through so much...I would have bought it by the case if I had known...also use a small nylon brush for the stubborn areas.
now get working Joe Attached image(s) ![]() |
macpro |
One more year... ![]() ![]() Group: Members Posts: 58 Joined: 30-May 05 From: N. Richland Hills, TX Member No.: 4,168 ![]() |
I was thinking of Glass Bead Blasting mine. Any thoughts about that?
Greg Fox (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) |
qa1142 |
Local NAPA wants $130 for 5 Gal (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
mihai914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None ![]() ![]() |
It may be cheaper, less time consuming and cleaner just to have someone clean it for you in some sort of cleaning bath.
Look locally for engine or tranny rebuilders or heavy equipment stuff. Chrome places also have cleaning tanks as wheel refinishers. Just a thought. You can always use the dishwasher, I'm sure someone did it in the past (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
I used castrol super clean full strength and a brass bristled toothbrush. Lots of soaking, scrubbing, soaking, scrubbing. Bead blasting would be quick but what would that do to the valves and seats if you didn't dissamble first.
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Buy stock in Berryman's then buy out the local FLAPS. Nothing made it easy but brake cleaner was best for me. I tried MEK, alcohol, and solvent. Incidentally, solvent is a very good penetrant through your skin so wear protection. Latex gloves will not work as some of the latex will be carried in with the solvent. Nasty!!
Use plenty of fresh air. It won't help the cleaning but it will save a few brain cell you can kill later with (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) . Dave |
qa1142 |
Dude
the 50+ Greatful Dead shows took care of the brain cells, (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/drunk.gif) |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
I use Purple cleaner to get rid of the grease and oil. Then come in with the bead blaster and knock all the carbon off the parts. This way you won't contaminate the media blaster.
I have also used gasoline to clean parts as well. I don't recommend it but it will do a great job. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
DNHunt |
Man if you are down that many brain cells already you really have to take care of what's left.
Dave |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
Easy-Off oven cleaner melts it away in minutes. use gloves and DONT breath it
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
I still like simple green......
i buy it by the gallon... |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
if you can find a company that does engine building local to you, they may have one of those hot cleaning systems/machines that will remove the crap and leave it nice and clean. use caution when soaking aluminum in one of those carb cleaning solvents. call around. can after can of berryman's, the residual mess, and the stink and loss of brain cells, is pointless. sometimes it's more efficient to pay someone to perform a task.
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
B-12 Chemtool(best), or brake cleaner(cheaper)
qa1142 |
qa1142 |
#4 with scuff
Lo-Fi Version | Time is now: 5th July 2025 - 03:30 AM |
