RennShifter, Vroom! Vroom! She's in... |
GTeener |
Nov 18 2005, 04:17 PM
914 Girl Group: Members Posts: 2,348 Joined: 25-June 04 From: SillyCon Valley Member No.: 2,249 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Got my Rennshifter installed finally. Wow, what a difference. Shifting is much easier. But...I still have probelms engaging 1st sometimes. Does my shifter need adjusting or is there a transmission problem? |
r_towle |
Nov 18 2005, 04:48 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
could be both.
R |
sjhowitson |
Nov 18 2005, 05:01 PM
Member Group: Members Posts: 478 Joined: 4-August 04 From: Moraga, CA Member No.: 2,449 |
GTeener |
Nov 18 2005, 05:07 PM
Pix of my interior with shifter?
sjhowitson |
Nov 18 2005, 05:14 PM
Yes please..Or a picture of that cute neighbor girl (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
GTeener |
Nov 18 2005, 05:31 PM
OK. This weekend. Maybe my cute housemate will pose too (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
olav |
Nov 18 2005, 06:18 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Next time you're at the gym in the morning get me so I can see the new shifter! |
GTeener |
Nov 18 2005, 06:22 PM
Tuesday 11/28. I'll try to remember to driver her that day (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
r_towle |
Nov 18 2005, 06:27 PM
That would be nice...
Who in the Massachusetts area has installed one of these. I would like to see one of these. Rich |
Mark Henry |
Nov 18 2005, 06:33 PM
I have one (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) works guud!
Gwen you may have one of your stops screwed in to far. |
TimT |
Nov 18 2005, 06:37 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Rich Im not in Mass but Ive installed a rennshift, and am quite happy with it.. Ill have the car out at Lime Rock in early april probably.. the car is hibernating now |
anthony |
Nov 18 2005, 07:31 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
I've got a Rennshifter that I'm ready to install. What other parts are the "while you are in there" stuff that should be installed? I suppose all new linkage bushings is mandatory.
r_towle |
Nov 18 2005, 07:35 PM
well, if you take out the motor....the rear suspension bushings, and while your r there the front suspension bushings....oh and there are new aluminum calipers that you might need...and if you do that...aluminum hubs and 911 rotors....mmmmm
You might want some interior stuff from morphenspectra like a new center console... leather seats and new door panels... And since you took the engine out.......................................................................... |
McMark |
Nov 18 2005, 08:11 PM
Gwen, does it grind or is it just hard to engage?
Anthony, the bushings in the universal joint where the first cone screw attaches are cheap and I've seen a few that are bad. Those bushings aren't always in the shift bushing "kits". |
ein 6er |
Nov 18 2005, 08:14 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
i recently installed a gen 1 rennshifter and found that just a 1 or 2 spline adjustment made a big difference, (tail shifter though). also check that your shift rod isn't binding on the clutch tube.
hope that helps!! |
JWest |
Nov 18 2005, 08:40 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
What are the actual conditions when it won't go in?
It's probably the typical Porsche syncro problem - they don't cope very well with engaging first at too low a speed - some (just enough) rotation is needed to allow the syncro to work to allow the dog teeth to mesh "just so." Worn parts (syncro, slider, dog teeth) just make this worse. It's really true of almost any gearbox, but it is a bigger problem with servo syncros. What if you double de-clutch on the downshift to first just before stopping - does is go in everytime? Is it an issue only while stationary? The radial adjustment is correct when the 1/2 shift can be made by just pushing the lever forward with no side-to-side correction, and the reverse lockout operation will determine the correct fore-aft position. As Mark said, back off the front stop bolt to see if that helps. |
jim_hoyland |
Nov 18 2005, 09:00 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Welcome to the club; just installed one too after tranny rebuild. I also have the 1st gear issue, I have found James advice sright on. Still a major improvement
RON S. |
Nov 19 2005, 10:53 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I got my gen2 shifter over the summer,beautiful,well working very professional piece.
It is WELL worth the price of it's admission (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Bigtime thanks James. Ron |
GTeener |
Nov 21 2005, 02:32 PM
Hard to engage, and a couple times I thought it was in gear and it popped out. It doesn't always groan like it used to though (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) It's odd, because the problem doesn't typically start until I've been driving the car a while. Like trying to downshift in traffic. Not sure what double clutching is or if I'm doing it (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
r_towle |
Nov 21 2005, 02:46 PM
Check your motor mounts...
if these are to loose or sloppy, your motor shifts position while you are driving....like when you accelerate really hard...then shift it moves and this makes shifting difficult. Also...the shifting will work better if your motor is sitting square to the chassis... Measure from the engine to the firewall on both sides... I found it could be off as much as 3/4 of an inch... Rich |
Lo-Fi Version | Time is now: 10th June 2024 - 07:34 AM |
