Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I have a possible line on a set of Venolia P/C's running 10:5 to 1 compression to put on my 2.7.
What I'll end up with is 40mm webers, late "S" cams and 10:5 to 1 compression. What do you guys think about the combo??? |
joea9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None ![]() |
I think with !0.5: 1 you may have to Run Twiin Plugs.... That compression is pretty High
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
I think its gonna suck.....
. . . . . . . . when a cop busts you! LOL 200+ hp? (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/Jumpy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/busted_cop.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/new_shocked.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/MDB2.gif) |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,506 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) And that's a problem because? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Twin Plug or Different Ignition (Crankfire??)
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Webers & S cams are OK in a race motor as is 10.5:1 compression with race gas. You gots a race car?
Allan |
Change of plans. Mechanic says compression is too high for what I need. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Going with Mahle euro P/C's. Shooting for 9:0 to 1... |
J P Stein |
'E' or Solex cams are a far better choice for a street car.
olav |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None ![]() |
Eddie914 |
Unregistered ![]() |
Great combination - lots of power, and fabulous throttle response, it will even lighten the car via your wallet since you will be paying$6.00 to 8.00 per gallon for race gas (100 low lead or 110 octane leaded).
10.5:1 is a bit high for pump gas. 9.5:1 is about the limit for single plug applicaitons with pump gas (depending on the quality of the pump gas ... pump gas is not the same in all parts of the country). You might be able to reduce the compression ratio with additional cylinder base gaskets, grinding of the piston crowns or grinding of the combustion chambers. It all depends on the price of the Venolia P/Cs and the amount of custom work you are prepared to do (or are prepared to pay to have done). Eddie |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Venolias were gone....actual pistons were Forged True with a CR of 11 to 12.5:1 depending upon installed height.... (IMG:http://www.914world.com/bbs2/html/emoticons/blowup.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/busted_cop.gif)
Well, back to the drawing board............. |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
I used Venolia Pistons on the first 911 engine I ever rebuilt. It was 2.2, when my dad and I measured the bores they were ovaled and tapered.. so we had them bored.. An outboard motor guy we knew hooked us up with Venolia.. the engine, after all was said and done was 2.35L The CR was 10.1:1 when measured...
It was a screamer that engine.. Yikes almost 25 years ago LOL I drove it for a few thousand miles, then balled the car up. 10.5 Is probably the max CR unless you commit to high octane, or twin plug heads..
go for a measured 9.5 |
brp914 |
what happened to your engine? last I heard, it torqued down ok and you were on the road.
Allan |
That's my goal... |
Allan |
Didn't work. Head was leaking for a long time and eroded the cylinder. One thing I learned is that unless you are a very good /6 guy (or girl), you will not know how to determine a head leak by ear.... |
J P Stein |
We (myself & another guy) rad 14.5 :1 Venolias in a 301 Chebbie back in the 60s.....drag racin'. We had to to run 2 compression washers on the plugs to keep em' off the pistons.
I ain't a big fan of trimming the deck height of 911 motors. Tain't worth the trouble for about .5 compression.....which don't give much bang for the buck. Even a point more would be worth maybe 10-15 hp & torque tops..better to get new pistons, me thinks. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,438 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
His heads are gonna need a cut because of the loose cyl/ heads /errosion. |
Allan |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Thanks for the advice. Mr. Make me spend more money.... |
J P Stein |
Yeah, but that can be shimmed back up at the cylinder base. If not, you gotta cut the chain boxes to suit the heads, right? Then you can get into chain length problems which can be cured by oversized idler sprokets...I'd pass. |
Lo-Fi Version | Time is now: 17th June 2024 - 09:25 AM |
