Brake question., Kneed to know... |
cantley914 |
Feb 1 2006, 07:47 PM
Pipeline surgeon Group: Members Posts: 306 Joined: 15-June 04 From: Cantley, Qc Canada Member No.: 2,210 |
Hello everyone
On a snowy canadian night, I just put back the braking system on my 73 914. While filling the brake fluid reservoir and pumping the brake pedal I noticed brake fluid coming out of the master cylinder at the brake pedal. Anything I can do to solve this problem without having to drain the system? Steph (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
double-a |
Feb 1 2006, 07:51 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
hm, probably no way to fix that without removing the mc. which sucks, because that's my personal least favorite job (so far) on these cars.
~a |
TimT |
Feb 1 2006, 07:52 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
sounds like you get to spend another snowy canadian night installing a new master cylinder (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
cantley914 |
Feb 1 2006, 07:59 PM
Should I change it or rebuild it. Are they rebuildable???
cantley914 |
Feb 1 2006, 08:02 PM
Not too bad to remove at this point for "honey" is still on the rotisserie.
TimT |
Feb 1 2006, 08:09 PM
If it were my car I would change it.
One reason the MC starts leaking when you do a bleed is that you get deposits in the MC bore. where the pedal usually stops, when you bleed your pushing the o-rings past these deposits tearing the o-rings. |
cantley914 |
Feb 1 2006, 08:13 PM
The MC has been removed from the car and sitting on a shelf, dry, for the past 12 years. I guess that explains the leak.
I have another one stillm installed on my parts car. I guess I`ll try that one (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) |
Eric_Shea |
Feb 1 2006, 08:24 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Rebuild your pedal cluster now as well. I've rebuilt a few M/C's no problems, fairly easy job.
Sounds like you've got it figured out... |
cantley914 |
Feb 1 2006, 08:30 PM
Last question,
Where can I get a rebuild kit? |
john rogers |
Feb 1 2006, 08:33 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
If it were me, I'd buy a new one since the m/c is sort of the pivotal main part of the braking system and it is nice to know it is perfect.
brp914 |
Feb 1 2006, 08:45 PM
Unregistered |
I've rblt 2 914 m/c. 1 worked great for years despite the fact it was not an ATE kit and I could only use half the parts. The next one worked great for exactly 1 day and failed at a very inopportune time. Got home, took it apart. Nothing wrong. Put it back, no workie. Never again. I wont cheap out with brakes anymore.
cantley914 |
Feb 1 2006, 08:59 PM
Yeah WTH I`ll go with a new one. You guys are right.
Thanks for all the advises. Long life to the 914 club What makes this club so great is the people. Steph (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 07:44 PM |
