Type 4 lifters |
Type 4 lifters |
914werke |
Feb 8 2006, 01:28 AM
"I got blisters on me fingers" Group: Members Posts: 10,138 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
how can you tell the differance between Hydro lifters and solid? Anyone got comparison pics?
Mark Henry |
Feb 8 2006, 07:17 AM
If you have them out take an old pushrod and press down in the cup. The guts of a hydro will move.
Also they have a circlip inside them...but so do some aftermarket solids. |
914ghost |
Feb 8 2006, 10:12 AM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
You'll know a solid lifter because it'll be all chewed to shit on one end. Unless you buy from Jake. Which I only reccomend if you only like to put an engine together once, I like doing it several times because obviously I have nothing better to do. And god hates me. (IMG:http://i27.photobucket.com/albums/c168/zer0b0y/case.jpg) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Tom Perso |
Feb 8 2006, 10:33 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
914werke |
Feb 8 2006, 10:48 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Wow.
Thas ugly. I ask cuz I tore down a supposedly hydro engine but it appears to have mixed parts IE new hyd WEB cam and steel one piece PR's but the lifters appear to be solids ? |
Mark Henry |
Feb 8 2006, 10:51 AM
That's why I snaged a spare set of ceramics last time I was down at Charles. Got them just before the prices went balistic.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
maf914 |
Feb 8 2006, 11:48 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
The ceramics were not exactly cheap to start with. How high is ballistic? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Mark Henry |
Feb 8 2006, 12:12 PM
$600.
Tom Perso |
Feb 8 2006, 08:29 PM
Did they look like this (on the left, SCAT ones)? (IMG:http://www.qtm.net/~persot/webcam/Lifter%20Comparison.jpg) (IMG:http://www.qtm.net/~persot/webcam/Lifter%20Wear.jpg) Those are SCAT high performance lifters. My Webcam 163/86b ate thru those in less than an hour. Get lifters from Jake - he at least knows what works and what doesnt. Those SCAT lifters may work OK for light spring pressure and near stock cams. But, if you've got some dual heavyweight springs, steer clear. Tom |
smac |
Feb 8 2006, 09:03 PM
Newbie Group: Members Posts: 39 Joined: 17-June 05 From: westminster Ca Member No.: 4,294 |
Here's my contribution to this very disturbing thread.
Attached image(s) |
smac |
Feb 8 2006, 09:04 PM
another!
Attached image(s) |
Type 4 Unleashed |
Feb 9 2006, 03:42 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Scat, has lube-a-lobes, for type lV's now, actually there's a hole from the Rockwell testing, that doubles as a lobe luber. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) Also, on the side of the lifter, where the side oiler is, a wider area was machined to allow puddeling of oil to better oil the lifter bore.
They go for around $80 buckaroos And yes I'am gonna buy a set. And I've had my share of flat cams (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) |
Twystd1 |
Feb 9 2006, 03:43 AM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Uhhh...
smac... I have a question for you. How long did that engine run with bad lifters??? I was wondring how the hell it ran long enough for that much damage to occur.. Just interested for no good earthly reason... I haven't seen anything like that since I had a tour of one of (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) engines... Man.. thats pitiful. Buy the engine from GEX? Or did Slits hand ya the wrong oil can during a lube change? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Twystd1 |
Tom Perso |
Feb 9 2006, 05:29 AM
Are the cam bearings down to the bronze?
(IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) I bet that was one noisy motor towards the end... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Tom |
Mark Henry |
Feb 9 2006, 06:51 AM
Scat lube-a-lobes are a big pile of steaming dog (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) I've had in the past year and a half 3 (customer built) engines that have these POS take a dump...2 of them on Scat cams! Hey...maybe I souldn't complain...keeps me in jobs. Look "Scat" up in the dictionary, very accurate description. |
914werke |
Feb 9 2006, 09:22 AM
Thanks Mark and they look like the middle lifter (WEB?)
And I already scored some Ceramics but Im tryin to positivly ID these lifters. |
Mark Henry |
Feb 9 2006, 09:29 AM
Right now the only things working for me is a matched set of cam and lifters from Jake. On low budget I've got away with a good used cam (hard to find) with stock (brazil) lifters and of course ceramics.
Jake Raby |
Feb 9 2006, 09:54 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I am working to drop the price of my lifters..... Maybe to 110 bucks a set from 180.00!
I'm testing another service from a different source for my Ion Nitriding... |
rhodyguy |
Feb 9 2006, 09:59 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
have things calmed down for you jake?
k |
Lo-Fi Version | Time is now: 8th June 2024 - 08:08 AM |
