Outer window squeegees stick to the window, How do i keep them from rolling in? |
Doug Leggins |
May 1 2006, 05:15 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I replaced the outer squeegees and cleaned the windows really well. Now when I roll down the window the squeegees stick to the windows and want to roll into the door. (IMG:style_emoticons/default/confused24.gif) They make it a PITA to roll down the windows. Anyone else have this issue after replacing the squeegees? What should I try to get the windows to work properly?
Allan |
May 1 2006, 05:16 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Maybe a little talc?
rhodyguy |
May 1 2006, 05:25 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
perhaps a smear of glycerine on the squeegees, let it penetrate a bit and wipe off the excess.
k |
retrotech |
May 1 2006, 05:28 PM
retrotech Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 |
I just had the same issue, but with my original rubber. Everything was fine, I removed the window, and when I replaced it, it sucked the rubber down every time. I adjusted the window so it barely touched, took the window in and out, cleaned the window several times. What ever it was, after sitting over night, something changed, works fine now. Walk away from it for a day. I was ready to throw the window in the trash!
sherman1 |
May 1 2006, 06:31 PM
Team McLaren Group: Members Posts: 57 Joined: 10-March 06 From: Woodside, CA Member No.: 5,697 |
What ever it was, after sitting over night, something changed, works fine now. Walk away from it for a day. Yep, that's usually how it works. Let it sit for a day or two, with the window all the way up & the rubber will kind of mold to the new shape. (IMG:style_emoticons/default/thumb3d.gif) |
bondo |
May 1 2006, 07:08 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Rain-X makes glass super slick.. maybe that would help?
davesprinkle |
May 1 2006, 08:37 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
I had the same trouble with new squeegees. Solved it with a coat of turtle wax on the glass.
Lo-Fi Version | Time is now: 9th June 2024 - 08:11 AM |
