POR-15 question... |
rtalich |
Oct 4 2006, 11:51 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
What kind of surface does this product leave? Is it smooth like a normal paint or is it like a rhino lining type of texture?
ptravnic |
Oct 4 2006, 12:14 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
smooth like a heavy oil based paint
jr91472 |
Oct 4 2006, 01:43 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
yes and black come out like a high gloss finish. I will use silver next time.
Jenny |
Oct 4 2006, 02:12 PM
Advanced Member Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None |
I remember someone said silver will fade to a yellowish-gold. The context was that it was painted on a roll bar, and the exposure to the sun faded it.
Jen |
ptravnic |
Oct 4 2006, 02:13 PM
POR's website says direct exposure to the sun requires some post application treatment.
KaptKaos |
Oct 4 2006, 10:10 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
(IMG:style_emoticons/default/hijacked.gif)
Where does one buy Por15? (IMG:style_emoticons/default/piratenanner.gif) /end (IMG:style_emoticons/default/hijacked.gif) |
BKLA |
Oct 4 2006, 11:17 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/hijacked.gif) Where does one buy Por15? (IMG:style_emoticons/default/piratenanner.gif) /end (IMG:style_emoticons/default/hijacked.gif) (IMG:style_emoticons/default/sad.gif) evilbay has some listed now.... http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWA%3AIT |
Lou W |
Oct 4 2006, 11:28 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
I remember someone said silver will fade to a yellowish-gold. The context was that it was painted on a roll bar, and the exposure to the sun faded it. Jen I used this instead of POR-15, it turned out really good, but it too will yellow unless it has a top coat; Rust Bullet |
ThinAir |
Oct 4 2006, 11:51 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I used this instead of POR-15, it turned out really good, but it too will yellow unless it has a top coat; Rust Bullet Any idea how much of this it takes to do a rear trunk floor? 200 square feet per gallon sounds like you could probably get by with a pint. |
Hammy |
Oct 5 2006, 01:48 AM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I used this instead of POR-15, it turned out really good, but it too will yellow unless it has a top coat; Rust Bullet Any idea how much of this it takes to do a rear trunk floor? 200 square feet per gallon sounds like you could probably get by with a pint. I did both the entire engine bay and rear trunk (about 2 or 3 coats worth) with a quart of POR-15 and had a little left over. So I'm sure a pint would be enough. It dries very glossy if on a smooth surface. Parts of my floor pan actually look like they have a pool of water on them because of the POR-15 paint look. But when the paint is exposed to the sun it loses its glossy-ness and gets flat black looking. QUOTE Where does one buy Por15? /end I found some at an automotive paint supply store. |
pfierb |
Oct 5 2006, 06:11 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
Buy it on line at their website WWW.por15.com
xsboost90 |
Oct 5 2006, 06:16 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
yeah they are in indiana-ok close to me- and ship super fast. Last time i bought some it was around $30 a quart. WILL require uv protectant coating if in direct sunlight. I did the bottom of my teener and undercoated over that- and the floor pans.
JB 914 |
Oct 6 2006, 11:38 PM
Daddy! Finish my car NOW!!! Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 |
i bought a gallon of it and had enough to do two floor pans. still had two quarts left that i donated to MattR and Skline. i think MattR used his. I bet Skline put it on his fruit loops.
Lou W |
Oct 7 2006, 12:27 AM
I used this instead of POR-15, it turned out really good, but it too will yellow unless it has a top coat; Rust Bullet Any idea how much of this it takes to do a rear trunk floor? 200 square feet per gallon sounds like you could probably get by with a pint. I bought the four pack, 1/4 pint each can, I opened each one as I needed them, I think there is a shelf life once its been opened. |
TimT |
Oct 7 2006, 01:04 AM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE I think there is a shelf life once its been opened. Yes buy the pints in a 6 pack and open them as needed. Dont open the larger containers unless you have a large area to cover, the leftover stuff will set up like a rock in a closed container. Storing it in the fridge helps prolong the life of opened and resealed containers. Also dont get any on your hootus |
JimSar |
Oct 7 2006, 01:28 AM
Fill 'er up Group: Members Posts: 64 Joined: 28-July 06 From: Vallejo, CA Member No.: 6,527 Region Association: Northern California |
I bought mine from www.rustymetalpaint.com. Free shipping for orders over $100, so I went with them. They're pushing new(?) products from KBS Coatings (www.kbs-coatings.com) and they gave me an 8oz can of Rustseal to try. Will report on the difference after I've tried both products.
Lo-Fi Version | Time is now: 10th June 2024 - 03:33 AM |
