Who has a Sniffer?, Exhaust Gas Analyzer. |
Series9 |
Oct 21 2006, 11:28 AM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
I'm looking at CO analyzers.
What do you have? recommend? cost? I'm sure a certain percentage of my business will involve setting up carbs (IMG:style_emoticons/default/headbang.gif) , so I'm gonna need the sniffer. Something portable would be nice. |
TimT |
Oct 21 2006, 08:29 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
A good high quality WB O2 sendor would be fine!
We have a few four gas analysers in the shop, but for most jobs a WB is fine. For the WBs we have MoTec and FJO and some of the newer lower cost units like PLX. I personally have two Tech Edge units.. |
TimT |
Oct 21 2006, 08:33 PM
Oh and before anyone says WBO2s dont measure CO.
They do... indirectly... there are relationships between Co O2 Nox etc that are very consistent |
Series9 |
Oct 23 2006, 07:05 PM
A good high quality WB O2 sendor would be fine! We have a few four gas analysers in the shop, but for most jobs a WB is fine. For the WBs we have MoTec and FJO and some of the newer lower cost units like PLX. I personally have two Tech Edge units.. Thanks Tim, but I haven't seen a portable WB O2 sensor? You know, something I can shove up the pipe of all my bitches. (IMG:style_emoticons/default/happy11.gif) |
anthony |
Oct 23 2006, 07:09 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Series9 |
Oct 23 2006, 07:16 PM
I've never seen one of those. Interesting. (IMG:style_emoticons/default/idea.gif)
root |
Oct 23 2006, 07:39 PM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
I've had an LM-1 (innovation) for over a year now installed in my stealth 914.
I mounted it in the glove box on velcro so I can whipit out when I want to slip it into some other tail pipe. I have it programed to average the A/F ratio then output it to an LED A/F gauge on the front of the glove box door. Don't know what I'd do with out it and a CHT gauge on the dashboard! (IMG:style_emoticons/default/driving.gif) |
TimT |
Oct 23 2006, 07:47 PM
PLX Devices
We have a few of these, they are workhorses, rugged,dependable etc. Use a relatively inexpensive Bosch sensor. FJO Wb sensor We also have on of these, ours is an older model which uses an NTK sensor, which when needing replacement will set you back about $150, as opposed to $40 or so for Bosch sensor MoTec The quality of this one is without reproach, but it is quite expensive. $1200 or so. th FJO was $800, and the PLX we have was $279 (when we purchased) Tech Edge I also have two of these wide bands. I built them myself for the hell of it. They work as well as our MoTec and 4 gas units. The Innovate is also very popular with the Pelican crowd |
Lo-Fi Version | Time is now: 16th June 2024 - 03:25 AM |
