JB 914 |
Daddy! Finish my car NOW!!! ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 ![]() |
Well i sold the engine in my V8 today to QSL914 (Mike) at least i know it's going to a good home and now i can put this bad boy into my V8 Car.
327 small journal crank beer can heads should be ~325HP and high rev most of this motor was purchased from Big Doug in Cypress who mostly lurks on the club. The rest was funded by my good friends at the poker table. So, i'll be pulling the motor out in the next few weeks and hauling the carcass off to paint to make it purtee. (IMG:style_emoticons/default/biggrin.gif) Thanks thanks for the purchase Mike! and good luck with your project. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
i saw that at Johns shop...
nice stuff! v8 car painted yet? |
JB 914 |
i saw that at Johns shop... nice stuff! v8 car painted yet? nope, now it will wait till i pull the motor out. Richard has been helping me sort out the stromberg mess with the 4 banger. Once i pull the motor out i'll have it towed to the paint shop and be done with that fuglyness. (IMG:style_emoticons/default/barf.gif) At least if i have a put it in BBQ for the V8 we it won't turn into a tear down party. (IMG:style_emoticons/default/dry.gif) |
Aaron Cox |
very cool!
BTW - how ya been? havent run into you for a year+!! how are the wife and kids? the boat? happy holidays Joe AA |
JB 914 |
too much work and not enough play for me. Wife and kids are all doing good. wanted to come to Joe Sharps for the toy run, but, just had too much other crap going on...
we need to have a Double Joe BBQ with some beer can chicken and pork. mmmmmmmmm |
marks914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None ![]() |
327, very nice choice. Should be a good fit for the car.
I am currently building a SBC 302, I was going to do a 327 but I came across a large journal 3" stroke crank. Mark |
dakotaewing |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region ![]() ![]() |
327, very nice choice. Should be a good fit for the car. I am currently building a SBC 302, I was going to do a 327 but I came across a large journal 3" stroke crank. Mark (IMG:style_emoticons/default/hijacked.gif) Mark - What pistons, heads, and cam are you using ??? |
marks914 |
327, very nice choice. Should be a good fit for the car. I am currently building a SBC 302, I was going to do a 327 but I came across a large journal 3" stroke crank. Mark (IMG:style_emoticons/default/hijacked.gif) Mark - What pistons, heads, and cam are you using ??? I am using these pistons: http://store.summitracing.com/partdetail.a...mp;autoview=sku -6.5cc dome should ie me 9.6:1 CR with 67cc iron heads. (camel hump style) I am not sure on the cam yet, I usually use a "marine" grind because of the flatter torque curve. Mark |
dakotaewing |
327, very nice choice. Should be a good fit for the car. I am currently building a SBC 302, I was going to do a 327 but I came across a large journal 3" stroke crank. Mark (IMG:style_emoticons/default/hijacked.gif) Mark - What pistons, heads, and cam are you using ??? I am using these pistons: http://store.summitracing.com/partdetail.a...mp;autoview=sku -6.5cc dome should ie me 9.6:1 CR with 67cc iron heads. (camel hump style) I am not sure on the cam yet, I usually use a "marine" grind because of the flatter torque curve. Mark Mark, I am using these pistons : http://store.summitracing.com/partdetail.a...mp;autoview=sku I am using a 76cc 441 head, but I am concerned about having a dog of a motor, based on compression numbers - It should be close to the same compression #'s you have - The picture shown of the piston is not accurate ... JB - Sorry to hijack your thread.... |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
I have been inside that particular engine whilst it was being built by others.
It has also spent hours on a spintron to check out clearences of all of the reciprocating assembly as well as checking oil flow from the bearings and pushrods. It was spot on......... Nice engine Joe. C |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
i've been dreaming lately of a 320cid, 3" stroke in a 400 block or a 353 3.25 stroke in a 400 block.
small displacement, slow piston speeds, large bore for nicely unshrouded valves, light weight roller valve train, should be quite a screamer with modest torque. wouldn't have to go with really big dollar short block as per the piston speeds would be much lower than a 3.48 stroke. i'm thinking a 7-8k spinner would be very do'able with this. |
Twystd1 |
While we are on the subject.
Does anybody here have a read of why no one uses an Aurora, quad cam, all aluminum engine for one of these conversions? Is it engine width or something I don't know about? I would think it is the perfect engine for a conversion. I haven't done any homework on this swap. I was just thinking it has the best of all the worlds. EFI, high HP VS weight. And their cheap. Anyone have a heads up for me? C |
messix |
the transverse engines have things hanging off the engine in weird places, coolant connections, water pumps, ingintion, and the engine mounts aren't swap friendly, they use the 60 degree v6 bell housing.
Twystd1 |
Thanks Troy....
I always wondered about that.... So I know this guy with a NEW, real authentic ZR1 cammer complete engine with EFI in his stash.... He paid 2500.00 bucks for it new from GM when they dumped all of their ZR1 inventory. Makes a man wonder......... Don't it...... OK, dream sequence finished. He ain't gunna give that engine up... C |
messix |
Thanks Troy.... I always wondered about that.... So I know this guy with a NEW, real authentic ZR1 cammer complete engine with EFI in his stash.... He paid 2500.00 bucks for it new from GM when they dumped all of their ZR1 inventory. Makes a man wonder......... Don't it...... OK, dream sequence finished. He ain't gunna give that engine up... C he'll make a nice little profit on that deal. uhm street rod...naw been done. zr1 teener.... yeehaw. ditch the stock ecm and go after market. those engines with stock hard parts are good for 500hp + easy. lingenfelter was getting that by tweaking the ecm. |
Twystd1 |
It's just a really sick thought....
"ZR1 Teener" If I were only rich and bit dumber than I am now................. That would be so dam kewl it almost hurts. C |
messix |
Type 4 Unleashed |
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None ![]() |
Hey Joe read up on this post:
http://www.914world.com/bbs2/index.php?showtopic=37181 So you can get rid of that setup you have. Just a suggestion (IMG:style_emoticons/default/happy11.gif) |
Type 4 Unleashed |
It's just a really sick thought.... "ZR1 Teener" If I were only rich and bit dumber than I am now................." That would be so dam kewl it almost hurts. C (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/happy11.gif) |
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
too much work and not enough play for me. Wife and kids are all doing good. wanted to come to Joe Sharps for the toy run, but, just had too much other crap going on... we need to have a Double Joe BBQ with some beer can chicken and pork. mmmmmmmmm I'm up for that.... :PERMAGRIN: Joe |
Lo-Fi Version | Time is now: 10th June 2024 - 07:58 AM |
