Is it loud!, Yes, that means it is running. |
KaptKaos |
Nov 15 2007, 11:28 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Thanks to Steve (ahdoman) and Mark(euro911) for their knowledge and help. I learned a ton and best of all, the car is running. Man, is it loud with those webbers! But it sounds so sweet.
I need to change the jets, because it's running rich. I'll do that in a few days. Hopefully I will be able to button up the rest of the things (HEs, rear valance, deck lid) and take her for a spin around the block. I can't wait. Oh yeah, likely will need to adjust the shift linkage then too (IMG:style_emoticons/default/laugh.gif) Thank to all that helped drop and reload the motor too. Aaron, Joe, Allan, Mark, Steve, Clayton (tech support) and my non-914s Mike and Randy. I appreciate it. Opps.. and Linda too and my wife and kids for putting up with me while the car has been on jackstands. |
swood |
Nov 15 2007, 11:35 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Sweet!
ahdoman |
Nov 16 2007, 12:11 AM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
We can all blame Joe for the price of gas since those carbs are sucking up a ton of gas! Hey Joe, leave some for the rest of us. Oh, and thanks for the cheeseburger!
Twystd1 |
Nov 16 2007, 12:33 AM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
YEAH...!!!!!!!!!!!!!!!!!!!!
Fix the rich problem ASAP... or you will be pulling the engine apart fast. You can't afford to wash the oil off the cylinders with fuel. cause the rings won't seat..... And ya have to do a top end hone with new rings.... Got it Bro..??? Cheers and good vibes. It's been a long journey. And I admire you for not quitting. Good Job, Joe. Clayton |
KaptKaos |
Nov 16 2007, 12:57 AM
You can't afford to wash the oil off the cylinders with fuel. cause the rings won't seat..... And ya have to do a top end hone with new rings.... Thanks Clayton. One question. This is not a new motor. Does the rich condition apply, assuming that the rings are seated already? |
Twystd1 |
Nov 16 2007, 01:42 AM
Used engine means the rings are already seated to the bores.
So your good to go....!!!!!!!!!!!!!!!! Just rejet when ya have the time to get it right. Maximum cheers to ya bro. Clayton |
Aaron Cox |
Nov 16 2007, 01:51 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
50 idles? how many turns out are the mixture screws?
32 vents? you might be close if they are. try leaning out the idle mixture screws.. too much and they should lean out and drop a cylinder, pull around a full turn out from there. what mains? what AC's? you are close mang! |
Allan |
Nov 16 2007, 09:29 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Lo-Fi Version | Time is now: 12th June 2024 - 05:00 AM |
