DIY 3-piece wheel change-easy as it looks?, Need advice on sealing goop in the middle |
Chris Pincetich |
Nov 30 2007, 05:13 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I've got some new to me but used 3-peice Keizer rims that are pretty awesome, and as a bonus I have 2 extra outer rim halves that can bump the width out a bit.
I'm a CSOB DIY 914 owner, and want to get out my torque wrench and power driver this weekend to take apart 2 rims and add the new halves. Is this OK to do or am I liable to fuch up the wheels in the process? Next ? - what should I use as the goop in the middle? Looks like clear silicone in there now. I've got my rear fenders out enough with the baseball bat roll for the 7" width with 205 Hooisers (AX). With the new halves I'll be at 7.5" and am crossing my fingers another few passes with the roller and heat gun will make it work in those rear fenders. Bonus photo (IMG:style_emoticons/default/beerchug.gif) |
Twystd1 |
Nov 30 2007, 06:05 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Clear silicone is what I used in the old race days.
Me thinks they use sumpin specific for these nowadays. So they dissasemble easier. Sooooo I just called a buddy at Kinesis. He says Dow Corning Silicone works great. Just use lacquer thinner or acetone to get the wheel half's IMPECCABLY clean before putting them together. That means keep hitting the wheel half's with a clean WHITE paper towel and acetone/LT until the towel comes out with NO color. Unless ya want to wait and find the "WORTH" silicone specific for wheel half's. There should be some REAL racers popping up to give you there input on this..... (unlike me) Clayton C |
grantsfo |
Nov 30 2007, 06:28 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
RTV Silicone Sealant
Dow Corning 832 Multi Surface Adhesive Sealant is reccommended by some manufacturers. Call Wade at Kiezer sure he can walk you though the process and reccomend the lastest stuff. Nice guy. Wade Husiman 712-737-3053 This post has been edited by grantsfo: Nov 30 2007, 06:29 PM |
stownsen914 |
Nov 30 2007, 10:02 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Call Wade at Kiezer sure he can walk you though the process and reccomend the lastest stuff. Nice guy. Wade Husiman 712-737-3053 And while you have him on the phone, make sure to ask about the torque spec on the bolts that hold the rim halves together. Also, whether the hardware needs to be replaced with every disassembly -- some wheel manufacturers recommend that. I have seen a wheel fail at a track event due to improper assembly, and it wasn't pretty. Don't be deterred though -- just follow the instructions. |
DanT |
Nov 30 2007, 11:57 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Nice Chris, those should help alot next season.
I will be running my 7" steelies, so your setup will be a bit lighter (IMG:style_emoticons/default/biggrin.gif) I have a brand new set of 710s for next season. Attached image(s) |
DanT |
Nov 30 2007, 11:58 PM
with these
Attached thumbnail(s) |
McMark |
Dec 2 2007, 11:39 AM
Chris Pincetich |
Dec 3 2007, 12:08 AM
Lazy weekend, and I'll be calling Wade for sure. I spoke with one fellow on the phone last month and he said that I can replace those centers with 4 spoke billet mag style if I wanted to later (IMG:style_emoticons/default/beerchug.gif)
I just didn't write down any details at the time. New hardware (same grade or better) was allready in the plan. Thanks for all the replies (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 10:10 AM |
