vesnyder |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 ![]() |
I am converting my D-Jet car to Weber's - what should I do with my fuel pump? Where can I get one of the required pumps? Do I still need the return fuel line? Should I put in a pressure regulator? Any tech article that talls about it (I have the one that highlights the revised wiring for the pump)?
Thanks |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
CB Rotary Pump. It's quiet and internally regulated. 3 PSI iirc.
Look up Sir Andy's pump jumper tech article. It will help with the wiring for the pump. There are 2 leads on the stock pump and two spade connectors on the CB pump. Only runs right one way. If you're not getting fuel, switch them. Good luck. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,252 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
CB Rotary Pump. It's quiet and internally regulated. 3 PSI iirc. (IMG:style_emoticons/default/agree.gif) article is here: http://www.914world.com/bbs2/index.php?showtopic=25954 (IMG:style_emoticons/default/bye1.gif) Andy PS: leave the return line in the car and just close it off. you never know if you'll need it again one day ... |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Brown wire is (-), black/red wire is (+). The Cap'n
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
CB performance rotary pump works great.
And the tech article on the subject is also very good combination of SirAndy's work and some tips form Bill Perry combined. http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php |
SirAndy |
CB performance rotary pump works great. And the tech article on the subject is also very good combination of SirAndy's work and some tips form Bill Perry combined. http://www.914world.com/specs/SirAndyCarbFuelPumpRelay.php oops, forgot that we made that into a tech article ... my bad ... (IMG:style_emoticons/default/slap.gif) Andy |
Lo-Fi Version | Time is now: 8th July 2025 - 03:51 PM |
