Don't laugh but..., Is anyone running front KYB inserts? |
Carlitos Way |
Feb 2 2008, 08:37 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
I'm in a financial bind... and need to replace front shocks. I'm thinking I can get a local flaps/shop to install whatever I can get... and I don't want to invest on high end shocks as I hope to go to a 5 lug set up at some point.
degreeoff |
Feb 2 2008, 08:42 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
they'll do the job...I had em for a couple years. Sure thats ur issue?
Allan |
Feb 2 2008, 08:46 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Have you considered Boge's? I had them on my /4 and they worked pretty well.
Not too spendy either. What are you planning to do with the car? DD, DE, A/X? |
Rusty |
Feb 3 2008, 05:13 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
No reason to laugh about that.
Boges aren't bad shocks... and you might want to put a WTB in the classifieds. Someone might have a set of take-off shocks that you could run for a year or so. P.S. If you can jack up your car and change a tire, you can replace your own shock inserts. Borrow the tools if you have to, but it's too easy to pay someone to do it. |
Spoke |
Feb 3 2008, 06:51 AM
Jerry Group: Members Posts: 6,990 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Have KYB's in the front of the red 71. They work and don't break the bank.
type47 |
Feb 3 2008, 07:00 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
i put them in for the same CSOB reason
rick 918-S |
Feb 3 2008, 07:26 AM
Hey nice rack! -Celette Group: Members Posts: 20,478 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I've used KYB's on several BMW's The sport gas ones are good. Don't get the old standard oil filled ones. BTW: I wen mine failed the store replaced them and allowed me to pay the difference for the sports.
tracks914 |
Feb 3 2008, 07:39 AM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I'm not sure what I'm going to do with this project car I 'm working on but for now I put KYB's all the way around. I haven't driven it yet (or will for about a year) but for under $200 they are all new and better than the worn out shocks I took off.
rhodyguy |
Feb 3 2008, 10:42 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,089 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
going to konis, bils, even NEW stock units is an exspensive prop for the budget challenged. the KYBs are 1000% better than old worn units. you don't need to spend your money farming out the all labor. the fronts can be done in about a 'no rush hour'. much less time the 2nd go round. for the rears, take the assems off, go to your local co that does shock/strut replacement, have them compress the springs in their fixture to loosen the top retaining nut, or plan on using the scary (to me)spring compressors. they should charge a minimal fee for this task. if you have your new rears, have them squeeze the springs on the new ones and put the nut on. quick, no pain, and again, they should charge very little for this minor service. if they quote you a lot of money to do this, keep calling around. it should take them 10 minutes, tops.
k |
Carlitos Way |
Feb 3 2008, 10:08 PM
Are these the right ones for a 914?
Twystd1 |
Feb 3 2008, 11:22 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
NO.
C |
Twystd1 |
Feb 3 2008, 11:33 PM
HHHmmm I found the KYB inserts on a web site for about 45 bucks. is that what you are seeing?
Twystd1 |
Feb 3 2008, 11:36 PM
What year is your car? There are different inserts for different year 914 front ends. Early VS Late.
And some have front ends have been mixed and matched over the years. C |
purple |
Feb 4 2008, 07:53 AM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
i have a lightly used pair i'll give you for the cost of shipping. PM me if you're interested.
Purple |
rhodyguy |
Feb 4 2008, 08:29 AM
that certainly sounds priced right. i always wonder what "slightly used" means. that site link provided was terrible and EXSPENSIVE. if you want brand new you can find them for cheaper. only difs i've noted on the fronts were for either 6s or 4s.
k |
Twystd1 |
Feb 4 2008, 09:33 PM
Differences are early VS late front ends. They make KYBs for both.
C |
Lo-Fi Version | Time is now: 5th June 2024 - 07:19 AM |
