> EGT sensor location
yarin
post Feb 20 2008, 07:02 PM
'14-X'in FOOL
I'm about to re-coat my exhaust and do a little bit of welding work so I figured why not weld on a few EGT 1/8" npt bungs while i'm at it. Does anyone know what the ideal position is for an EGT sensor is? Also which sensor is recommended?
orange914
post Feb 20 2008, 07:36 PM
http://5starmediaworks.com/index.html
QUOTE(yarin @ Feb 20 2008, 05:02 PM) *
ford muscle.com (?) recently did a o2 senser comp. on the best wide band
the closer to the head the better, for quick heating and acuracy. you can go down stream but you'll need the more expensive 3 wire units that self heat
geez... sorry i was thinking you said o2 sensor (IMG:style_emoticons/default/blink.gif)
close to the head would be my quess
mike
McMark
post Feb 20 2008, 07:40 PM
914 Freak!
Yup, close to the head. I put them near the 90* bend where the exhaust changes direction from downwards to backwards.
I also like the clamp on EGT probes just fine. (IMG:style_emoticons/default/wink.gif)
toon1
post Feb 20 2008, 10:42 PM
QUOTE(McMark @ Feb 20 2008, 05:40 PM) *
Hey Mark , what ex. temps are you seeing??
Twystd1
post Feb 20 2008, 11:17 PM
You don't want to know... really.....
I'm with Mark.
I saw a high of 1350 at peak torque for short durations floored going up hill.
(Less than 5 seconds at that temp)
When the engine pulls past peak torque. The temp goes down fast.
Normal driving. 850 - 1200+ going up hill.
Hi EGTs at cruise throttle openings on a flat freeway don't mean much to me. High (percieved) EGTs at cruise won't hurt the engine.
The temps of when the engine is trying to achieve max torque and HP has great meaning to me. (I.E. WOT)
On carbs. 2.5 litre Type IV with 9.5 - 1 static CR and a High RPM cam. Revs to 8K+ no probs.
I also had 1/8 holes in the 90 degree bend below the head as per McMark.
I think Chris-N-Prider now has those headers on his car. Still has the 1/8 holes for the quad EGT probes I think.
Thats my experience. Yours may well be different.
Clayton
McMark
post Feb 21 2008, 12:28 AM
914 Freak!
I'm seeing between 40 degrees and 65 degrees.
My car's been sitting... (IMG:style_emoticons/default/av-943.gif)
rhodyguy
post Feb 22 2008, 09:56 AM
these suggestions are for cars with headers, yes? how would one deal with egt sender placement when running ss hes?
k
- Lo-Fi Version Time is now: 10th March 2026 - 07:34 AM
