Hey /6 guys 911 2.4 engine question(s), AKA I have oil issues :-( |
GaroldShaffer |
Jul 22 2008, 05:20 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
The short version:
I have a old 914 FP race car that is "this close" to having the /6 conversion completed. The engine is a 2.4 911 T with carbs. All new -12 areo quip lines, new oil tank, thermosta, and remote oil filter console. Car is at Brad Mayuers shop. Here is the issue with everything hooked up Oil will build up in the crank case to the point the oil tank starts to suck air and the over flow tank fills with oil. When drained, over 1 1/2 gallons of oil comes out of the crank case. Now with the remote oil filter, oil cooler and such bypassed and the line connected back to the oil tank the oil flow is better, not great, but better. When drained about 3 quarts of oil comes out of the crank case. Seems to Brad that I have a scavage pump problem, yes? Is there anything else that we should look for? If Brad is stumped, then I sure the hell have no clue. I will not take this engine apart. If it comes to that then my /6 project is done for a while until I build up enough funds to get another engine. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/headbang.gif) |
Root_Werks |
Jul 22 2008, 05:26 PM
Village Idiot Group: Members Posts: 8,334 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
More info:
What type of oil tank? You mentioned remote filter etc. Describe your system as best you can for us. It makes a difference. If you have a cooler, there should be a thermostat that bypasses it until needed. Your remote components might be funky? The oil tank could also be an issue. |
sixnotfour |
Jul 22 2008, 05:30 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
take the sump plate off and have a look see, at the the pickup tube on the pump
TimT |
Jul 22 2008, 05:50 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE at the the pickup tube on the pump Yes sounds like a scavenge problem. A few years ago on my car the pickup broke off the body of the oil pump while I was changing the oil. I was able to jb weld the tube back on after super cleaning and drying the oil pump body with brake cleaner. |
shoguneagle |
Jul 22 2008, 10:38 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Brad Mayeur is one of the most experienced Porsche guys in the Mid West. You have taken it to the right shop for maintenance. I would not rule out the engine yet. The guys on this board will provide info and advise.
What exactly is Brad telling you?? |
GaroldShaffer |
Jul 22 2008, 11:36 PM
Brad is telling me he doesn't know why this is happening. He feels it is the scavage pump, but isn't 100% sure. I trust Brad & Michael.
QUOTE More info: What type of oil tank? You mentioned remote filter etc. Describe your system as best you can for us. It makes a difference. If you have a cooler, there should be a thermostat that bypasses it until needed. Your remote components might be funky? The oil tank could also be an issue. I have a PMS 16 quart oil tank (#OIL 08-0011-DB), PMS Remote oil filter console (#OIL09-0304), using a PMS 180 Degree MOCAL OT2 type thermostat (#OIL-12THER). This pitcures below shows the way it was setup when the /4 was it. EVERYTHING for the oil system is NEW It is setup the same way, but with bigger oil tank, lines, oil filter, ..... The only unknown is the engine itself. It runs great, just doesn't have the butt to pump the oil through the filter, cooler and back to the tank, or so it seems. Attached image(s) |
Justinp71 |
Jul 23 2008, 11:29 AM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Well in basic principal either what ever pushs the oil out of the motor (scavange pump) is not working or there is a blockage in the oil passage going to the oil tank.
Maybe drain the oil lines from the motor exit to the oil tank and see if you can push air thru them. Would it be possible to have a defective thermostat or something? |
elmonte |
Jul 23 2008, 03:06 PM
Member Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
Not to state the obvious, but do you have the sump plate in the correct orientation,the drain plug can't be under the pump pickup. Just a thought.
Cheers |
Root_Werks |
Jul 23 2008, 04:24 PM
Might not be the right oil tank? Last 4cyl engine wasn't really a true dry sump like the 6cyl is. They need a rather large pick up line.
Others have mentioned the pick up tube. I would check that as well. |
Lo-Fi Version | Time is now: 6th June 2024 - 08:07 PM |
