Sloppy shifting alternative |
r_towle |
Apr 3 2003, 06:18 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I made these and they are great...really made a large difference.
r_towle |
Apr 3 2003, 06:19 PM
another
r_towle |
another
r_towle |
Apr 3 2003, 06:21 PM
oops, i meant this one
r_towle |
Apr 3 2003, 06:23 PM
So,
I riveted the firewall bushing in. I made the cup bushing taller to overcome the fact that it no longer snaps on, it just sits there and the ball slides in and out of the bushing. the one on the transmission I bought from PP. I was able to make the tolerances much closer, used waterproof grease, and it shifts nice and solid now. Rich |
MarkV |
Apr 3 2003, 06:29 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Nice work, is that brass ? I can't tell from the photos. Does your camera have a "macro" button?
nice squirrel (IMG:style_emoticons/default/boldblue.gif) |
914werke |
Apr 3 2003, 06:43 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Mueller |
Apr 3 2003, 06:47 PM
Petrified Squirrel Meat???
If you used an Oilite bushing, no extra grease would be needed........ |
TimT |
Apr 3 2003, 06:48 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Nice work on the bushings!! are you planning on producing anymore? Id be interested in a set..
Now to another topic.... the squirrel I got this image in a spam email the other day LOL (IMG:style_emoticons/default/mueba.gif) |
MarkV |
Apr 3 2003, 06:49 PM
What is the difference?
Bronze has a higher nickle content than brass and that makes it more durable. Correct me if I am wrong. (IMG:style_emoticons/default/pray.gif) |
Bleyseng |
Apr 3 2003, 06:54 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yup, and has more letters.
Geoff |
r_towle |
Apr 3 2003, 07:16 PM
used brass, cheaper, will last longer than plastic and it has the word ass in it....
Lawrence |
Apr 3 2003, 07:21 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
They certainly are cool looking. Let me be devil's advocate for a second:
Wasn't the idea of making them out of plastic so that the plastic would wear before them metal did? Will the metal cause additional wear on the shift linkage? -Rusty |
TimMartin |
Apr 3 2003, 07:25 PM
Newbie Group: Members Posts: 45 Joined: 16-January 03 From: Morgan Hill, CA Member No.: 157 Region Association: None |
Bronze is a copper and tin alloy. The high copper content makes it more corrosion resistant than brass. It is also harder and stronger than copper. Bronze can be made to be porous, which holds the oil in the bushing/bearing making for it "self-lubricating" or "oil-retaining".
Brass is an alloy of copper and zinc. (2/3rds copper 1/3rd zinc normally) Either can contain other metals, bronze bushings often have silicon in them for instance. .tim PS: yes, the bushing should always be designed to wear before the linkage. But brass should in fact wear quicker then the steel linkage. Although not as fast (or as low friction) as with a plastic. |
r_towle |
Apr 3 2003, 07:27 PM
well,
Steel is harder than brass. I rounded the edges inlet and outlet where needed to ensure smooth travel and no uneeded wear on the rod. And the tolerances were terrible when I bought a new set of plastic bushings. I made these alot tighter, one one thousandth's of an inch for grease only. I looked into using graphite impregnated bronze, but it was to costly to buy the stock, and a friend had the spare bronze, so that made the decision. |
r_towle |
Apr 3 2003, 07:46 PM
I looked into doing this for sale...
It will work if I do 25 or more sets, till then its to expensive... Rich |
seanery |
Apr 3 2003, 08:35 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
you can probably count me in for a set for the race car.
r_towle |
Apr 3 2003, 08:37 PM
thats two then
MarkV |
Apr 3 2003, 08:41 PM
So how much closer is the tolerence ? (IMG:style_emoticons/default/confused24.gif)
Jeroen |
Apr 3 2003, 09:02 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
izzat for a tail or a side shifter?
(I'll take a set if they're for the tailshifter) cheers, Jeroen |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:53 AM |
