Front Windshield Aluminium Trim Removal, How do I take it off? |
EdArango |
Aug 29 2010, 07:59 PM
914 Enthusiast Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California |
What's the best way to remove the windshield trim without bending or breaking any part of it.
Thanks Guys!!! ED |
rick 918-S |
Aug 29 2010, 08:08 PM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
There are very few guys that can remove the windsheild trim without some limited damage. The 914 windsheild trim is the most fragile of all. I was in the bodyshop/resto bus for 20 years and even I can't guarantee zero damage. your best bet is to get a windsheild trim removal tool. Eastwood likely sells them. Hook the clips and becareful.
EdArango |
Aug 29 2010, 08:13 PM
There are very few guys that can remove the windsheild trim without some limited damage. The 914 windsheild trim is the most fragile of all. I was in the bodyshop/resto bus for 20 years and even I can't guarantee zero damage. your best bet is to get a windsheild trim removal tool. Eastwood likely sells them. Hook the clips and becareful. Wow! Rick....Thanks for the input. I'll be as careful as possible!! |
cary |
Aug 30 2010, 07:16 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
They're pretty soft. Just take your time. You should be able to reshape them to put them back on.
jim_hoyland |
Aug 30 2010, 07:26 AM
Get that VIN ? Group: Members Posts: 9,320 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Ed,
There's a local glass guy in Orange County that has done a lot of 914s oer the years. He's probably your best bet, and he will come to you. I'e used him 5-6 times over the past fifteen years. He also installs windshield and rear windows at very resonable prices. Company is L & R Glass, contact is Rufino 714-292-5811 |
IronHillRestorations |
Aug 30 2010, 07:28 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If it's been silicone'd in you won't remove it without bending it. Your FLAPS may have a trim tool, mine did.
The end of the tool looks like a big wide arrow point. You carefully work the tool in between the trim and the glass, and then work the "barb" of the arrow point between the trim and the plastic clips to lever it away from the clips, and the trim will lift upwards a little off the clip. As Rick said, it's not easy! |
dr914@autoatlanta.com |
Aug 30 2010, 09:19 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
What's the best way to remove the windshield trim without bending or breaking any part of it. Thanks Guys!!! ED Many Ed, push a razor blade down between the trim and the frame cutting the plastic mounting clip peg and then the "stuff" just falls off. Usually however, the corners or top clip are loose anyway and after their removal, the larger pieces can be slid off, carefully of course. Even if slightly bent, it can easily be straightened. |
carr914 |
Aug 30 2010, 05:29 PM
Racer from Birth Group: Members Posts: 119,041 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Easy, do 130mph down the back straight of Sebring
Here I am coming in the Pits with about 70% of the trim gone Oh Wait, you don't want it bent. Sorry I can't help you. The Corner Workers brought me back some of the most mangled up Aluminum I have ever seen. I will never use the trim again. I intend to use the rubber trim that is somewhat like the 911's T.C. |
iamchappy |
Aug 30 2010, 07:49 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I was able to work a plastic zip tie under the trim and shimmy it pulling up on it at the clips as i got to them and pop the trim as i went - support the trim with your hand as you go so when it does pop you dont bend up the trim, the only damage to the trim is underside were the clip hooks into which gets pulled out a bit (not visible from above) but was easily bent back with a paddle nose pliers.
I bought one of those trim removers all it did was chip and cup the edge of the windshield glass and feared it would break it. If there is a technique to using one i couldn't figure it out, i found it very hard to hook the point of the tool in between the clip and the trim. |
Aug 30 2010, 08:56 PM
Thanks for the tip George! I like the idea of just writing off the clips and cutting right through them.
Mikey914 |
Aug 30 2010, 09:40 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have the tool I've been selling for $12, but I bet you could find a mamber here that would loan you one. Heck, I'll loan you one, but the shipping winds up being about $10 round trip.
Just let me know, but why buy clips if you don't have to? |
Bartlett 914 |
Aug 31 2010, 05:46 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
George has the right idea. My concern is the blade being strong enough. I used a sharpened putty knife. and drove it down next to the clip. I them hammered it sideways and cut the clip. This will damage paint so it not best for all situations.
iamchappy |
Aug 31 2010, 07:07 AM
The right idea only if your are planing on removing the windshield and replacing the clips. The Zip tie worked well for me.
MoveQik |
Aug 31 2010, 07:55 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Easy, do 130mph down the back straight of Sebring Mine came off in similar fashion. I only had to do 70 on the freeway. Worked just as well as your idea but not nearly as fun to tell the story. (IMG:style_emoticons/default/smile.gif) |
biosurfer1 |
Aug 31 2010, 09:26 AM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Mine too...heading back from Santa Cruz going 80mph on 680 and all of a sudden it whips off and hits my hand, which was hanging out the window....about scared the crap out of me.
iamchappy |
Aug 31 2010, 09:40 AM
I guess a leaf blower or compressed air blow off tool maybe the easiest way.
bulitt |
Aug 6 2013, 04:25 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Saw the razor blade trick mentioned by McMark and I see in this thread George also mentioned it.
Worked perfect, zero damage to the trim. Insert the blade over the plastic retainer Tap down with a hammer Clip breaks and trim lifts right off. |
Mikey914 |
Aug 6 2013, 05:02 PM
The razor trick is only good if you plan to replace the clips.
Jeffs9146 |
Aug 6 2013, 07:08 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have been using the razor blade for years and it works great! |
John1180 |
Aug 8 2013, 10:48 AM
Newbie Group: Members Posts: 36 Joined: 27-February 13 From: Seattle Member No.: 15,590 Region Association: None |
Lo-Fi Version | Time is now: 11th June 2024 - 04:58 AM |
