transmission inspection |
914itis |
Mar 15 2011, 12:48 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Is there a way for a novice to open some part of a sideshift transmission to inspect for defects without taking the while thing appart? I guest Dr Evil will shine in..
Jeffs9146 |
Mar 15 2011, 12:59 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Yes but you will need a gasket!
Remove the tail cone and inspect the first gear teeth and syncro. Those tend to fail first and will give you a fair indication of the over all condition of the trans! |
914itis |
Mar 15 2011, 02:17 PM
Yes but you will need a gasket! Remove the tail cone and inspect the first gear teeth and syncro. Those tend to fail first and will give you a fair indication of the over all condition of the trans! Do I need tp drain the oil and what type and quantity to use for refill ? |
McMark |
Mar 15 2011, 02:21 PM
Yes you have to drain it. I like Swepco (available from GPR).
dion9146 |
Mar 15 2011, 03:34 PM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
Is there a way for a novice to open some part of a sideshift transmission to inspect for defects without taking the while thing appart? I guest Dr Evil will shine in.. I think it depends on what kind of defects that you think you are looking for. Pulling the tail cone will show you first/reverse. Chances are, your syncro is bad, or the dogteeth have seen better days. But if you are suspecting any other issues like other sycros or problems with 2-5, you will need to slide out the gear stack. Again, not a big issues but it is a little more involved. Look at some of the classic threads for lots of great pictures. My first experience as a 'novice' was completely dismantling a spare transmission so I could see how it worked. Then I rebuilt my good transmission, and with the help of some of the classic threads, it turned out great. http://www.914world.com/bbs2/index.php?showtopic=18128 Dion |
jimkelly |
Mar 15 2011, 05:13 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
what are your symptoms?
914itis |
Mar 15 2011, 05:54 PM
what are your symptoms? No symptoms I just got it from a member here, the car was sitting. He does Nit know the history. He shifts it without the car moving and he says it feels good. I currently bbe a ti shift and I will be using it to convert to side. I just would like to take a look t it before doing the conversion. Any toughta and ideas are welcome. |
jimkelly |
Mar 15 2011, 06:02 PM
look at this
http://www.914world.com/bbs2/index.php?showtopic=18128 target= examples of - syncro rings - dogteeth - sliders Attached thumbnail(s) |
Dr Evil |
Mar 15 2011, 07:35 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Pull the stack
r_towle |
Mar 15 2011, 08:47 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You could get a bore scope from home depot (I need a good excuse to get one of these)..
It might fit inside the shifter console hole to allow you to look at the sliders... Rich |
r_towle |
Mar 15 2011, 08:48 PM
Dr Evil |
Mar 19 2011, 10:24 AM
You could get a bore scope from home depot (I need a good excuse to get one of these).. It might fit inside the shifter console hole to allow you to look at the sliders... Rich Or you could take it to a hospital and CT it, or you could just pull the stack and have ll the answers for next to no cost :rolleyesL |
914itis |
Mar 19 2011, 10:46 AM
You could get a bore scope from home depot (I need a good excuse to get one of these).. It might fit inside the shifter console hole to allow you to look at the sliders... Rich Or you could take it to a hospital and CT it, or you could just pull the stack and have ll the answers for next to no cost :rolleyesL I decided not to open it I am putting it in the cr as we are speaking. Of something is wrong I will take a drive to drop it off your way. BTW what kind of oil you recommend puttingbin there and how do I know when its full ? |
Dr Evil |
Mar 19 2011, 02:55 PM
Click on my 31 pages of notes link in my sig. It goes over oil, filling should be done after you remove the fill plug FIRST. Then, you remove the drain plug and fill it until it runs out of the fill plug hole.
Lo-Fi Version | Time is now: 7th June 2024 - 09:53 PM |
