Not all targa tops are the same |
patssle |
May 4 2011, 05:20 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
So I bought an extra targa top off Craigslist to experiment with LineX as a re-coating. It came out nice, so I'm going to use it.
Apparently the latches and tops are slightly different. As shown in the picture, my original latches do not latch, the handles hit the top. But the new one single one that came with the targa does work. So I either need to make the old ones work or buy a 2nd latch of the "new" style. Any thoughts? |
windforfun |
May 4 2011, 05:26 PM
Senior Member Group: Members Posts: 1,846 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Your original latches don't appear to be stock. Also, the tops aren't always interchangeable from year-to-year.
Mike Bellis |
May 4 2011, 05:29 PM
(IMG:style_emoticons/default/agree.gif) Your original handles are not original...
SirAndy |
May 4 2011, 05:34 PM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Apparently the latches and tops are slightly different There are two versions of the tops. Early and late. Do a search here for a nice thread with lots of pics showing the differences. However, your "original" latch appears to be just a one-off where someone either fixed a broken handle or cut the handles to add an additional loop. (IMG:style_emoticons/default/shades.gif) |
patssle |
May 4 2011, 05:43 PM
Interesting. Well I reversed the handle on my "original" and it now works. All is good!
mgardstr |
May 4 2011, 06:29 PM
Newbie Group: Members Posts: 11 Joined: 13-January 11 From: Birmingham Member No.: 12,587 Region Association: South East States |
I didn't know there were two different tops. Will they interchange? I have 4 tops and I never looked to see if they were different.
Are there any pro/cons for using either version? |
Krieger |
May 4 2011, 06:34 PM
Advanced Member Group: Members Posts: 4,729 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Early is thinner and lighter.
patssle |
May 4 2011, 06:39 PM
On my "original" top, there is a slight 1/2" extrusion where the latches bolt on. On the replacement, it's all flat.
SirAndy |
May 4 2011, 07:39 PM
Will they interchange? Yes, but they will leak as the seals are not going to seal correctly against the door glass. Btw. i found the thread i was referring to by searching for "+early +top" ... Using the search is really not that hard guys ... (IMG:style_emoticons/default/rolleyes.gif) http://www.914world.com/bbs2/index.php?showtopic=73129 (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Hammy |
May 4 2011, 10:42 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
How's the Line X look?
patssle |
May 5 2011, 09:53 AM
It's pretty shiny in the sun, looks fantastic in the shade. I'm sure some won't like the shinyness, but I think it looks good. Plus I don't really drive with the top on when it's sunny!
I'll post some pics later. |
VaccaRabite |
May 5 2011, 11:43 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Will they interchange? Yes, but they will leak as the seals are not going to seal correctly against the door glass. Andy Mother F@@ker! I bet that is why the top I have seals so badly at theside windows. And it's painted to match my car too. |
Phoenix-MN |
May 5 2011, 11:50 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Will they interchange? Yes, but they will leak as the seals are not going to seal correctly against the door glass. Andy Mother F@@ker! I bet that is why the top I have seals so badly at theside windows. And it's painted to match my car too. Ok, another twist (IMG:style_emoticons/default/dry.gif) Early tub '71 with '74 doors and glass. Which top is going to fit correctly? |
SirAndy |
May 5 2011, 12:05 PM
Will they interchange? Yes, but they will leak as the seals are not going to seal correctly against the door glass.And it's painted to match my car too. Ok, another twist (IMG:style_emoticons/default/dry.gif) Early tub '71 with '74 doors and glass. Which top is going to fit correctly? Late. The top needs to match the door glass. (IMG:style_emoticons/default/bye1.gif) |
sww914 |
May 5 2011, 01:33 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Oh SHIT!
I have one early and 1 late door on my car. I guess it really is supposed to leak like that. |
Lo-Fi Version | Time is now: 12th June 2024 - 01:08 AM |
