oil lines, can figure where to put them |
machina |
Jun 19 2004, 01:23 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
just can't figure how to run two -10 lines to the front. I don't mind running them in the cabin but once you go thru the first bulkhead, the steering rack is in the way, looks too tight to jam them in there.
already have fuel lines in the right side heater tube and the battery cable on the left side heater tube. running them down the rockers and inside the wheels well just seems sloppy to me. I know the factory does this on the 911's but still. help (IMG:style_emoticons/default/headbang.gif) dr |
machina |
Jun 19 2004, 01:29 PM
will they clear above the crossmember and not interfere with the steering rack.
if youv'e btdt, chime in. dr Attached image(s) |
Joe Bob |
Jun 19 2004, 01:43 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Under the doors inside the rockers or thru the heater tubes of you have no heat....
machina |
Jun 19 2004, 01:50 PM
thanks mike,
do you think its a bad idea to run the ss lines in the heater duct with the battery cable? I can picture the ss braid rubbing thru the battery cable insulation. Is this a non-issue or should I re-route the cable? dr |
Joe Bob |
Jun 19 2004, 02:24 PM
Run the lines up the other side....
machina |
Jun 19 2004, 02:26 PM
the other side already has 2 -6 fuel lines in it.
dr |
Joe Bob |
Jun 19 2004, 04:53 PM
Well then, the cabin or the rockers....
machina |
Jun 19 2004, 06:28 PM
talking about it made me decide to move the fuel lines over to the left side with the battery cable so the bigger oil lines can fit in the right side heat tube.
I like a clean install. The inlet and outlet for the oil pump and return are on that side of the motor as well. thanks mike. dr i'm not a concours weenie, just a AN hose running SCCA moron. |
SirAndy |
Jun 19 2004, 06:41 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
run them from the front trunk through the little passage tunnel inside the pass. side footwell, from there, next to the pass-side long to the back, then through the firewall ...
i know brad has good pix of that setup somewhere ... Andy |
lapuwali |
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
You should really wrap braided lines in something like that nylon spiral wrap, or large rubber hose, to keep it from rubbing against everything it sight. They'll rub all the paint off the inside of the rockers.
SirAndy |
have the lines enter the small tunnel on the front firewall, route through tunnel ...
Attached image(s) |
SirAndy |
Jun 19 2004, 06:42 PM
tunnel exits into the pass. footwell, from there run alongside the long and then through back firewall ...
Attached image(s) |
TimT |
Jun 19 2004, 06:56 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
SirAndy |
Jun 19 2004, 07:04 PM
btw. if you still have the longs empty (which you said you hadn't) you can run the oil lines from there straight into the long without going through the top heater outlet.
there is a access hole in the side of the long where the blue arrow is pointed, it's covered with a tar-patch. this will give you easy access to the long tunnel. that way, you minimize the length of oil-line inside the cabin (they DO radiate heat) ... Andy Attached image(s) |
machina |
Jun 19 2004, 08:45 PM
QUOTE(SirAndy @ Jun 19 2004, 08:41 PM) have the lines enter the small tunnel on the front firewall, route through tunnel ... you da man (IMG:style_emoticons/default/pray.gif) i was under the car today for an hour trying to figure out where that little passage went to. I thought the crossmember was in the way but didn't understand the geometry of that little passage. I may do it this way no so I don't have to undo the fuel lines and battery cable. The install on those it pretty nice already. Also, I like the direct and shorter run this route gives to and from the motor. thanks, dr |
Trekkor |
Oct 17 2005, 11:23 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I did mine that way!
Attached image(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 02:53 PM |
