help me identify a couple pieces, tearing down a donor engine |
bradtho |
Sep 5 2011, 03:58 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I picked up a fully intact donor engine (72 1.7l) and am tearing it apart for parts and fun. I've hit a couple items that I don't know what they are. can you help identify?
#1 - up first is a vacuum hose junction. you can see it attached to the fan shroud near the oil filler. My DD is also a 72 1.7l but this piece is quite different. curious about the change. any info? #2 - this is some kind of heat activated spring that controls the flappers on the cooling tins. what do you call this thing? #3 - finally, this came in a bag of loose parts with engine, so I don't know the location. it looks familiar, but I can't seem to find it on my driver. |
stugray |
Sep 5 2011, 04:28 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
#2 is a thermostat
#3 is the cover for the shift linkage where it comes out the firewall. |
clow |
Sep 5 2011, 04:32 PM
The Kid Group: Members Posts: 164 Joined: 7-September 10 From: Ontario, Canada Member No.: 12,151 Region Association: Canada |
1. I don't have anymore info other than its a junction 2. Its a thermostat that controls the heater flaps. http://www.914world.com/bbs2/index.php?showtopic=30107 3. Could be where the shift rod meets the tranny?Thats my Guess Cheers |
914werke |
Sep 5 2011, 04:57 PM
"I got blisters on me fingers" Group: Members Posts: 10,115 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
#1 is commonly known as a flashback valve.
Your thermostat appears to be toast. |
bradtho |
Sep 5 2011, 05:18 PM
thanks all. super helpful as always.
how can you tell the thermostat is toast? its been covered in oil, so I really haven't bothered messing with it yet (plenty of other things to figure out). |
wingnut86 |
Sep 5 2011, 05:50 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
any time the thermostat is completely spread out from end to end of the assembly mount/bracket, then your thermostat is bad.
make sure your bracket is good and square, but I agree that it' looks bad. Fully collapsed it usually leaves a good bit of space on the end where the cable feeds in. Buy another one... |
Lo-Fi Version | Time is now: 31st May 2024 - 11:58 PM |
