| DRPHIL914 |
Dec 23 2011, 11:50 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
So my wiper fluid has never worked. I did not see the hose was disconnected @#$%&. A quart id water on the floor. Now someone tell me how and where is does this attach?
| SLITS |
Dec 23 2011, 11:56 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Air line from spare tire to top of WW reservoir
Exit from bottom of WW reservoir to column switch on late cars or dash switch on early cars ... from switch to "T" behind the fresh air box and then to the spray nozzles on the cowl. |
| SirAndy |
Dec 23 2011, 12:02 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,563 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If the hoses haven't been used in a while, they're probably rotten.
I've seen that many times. It's not that hard to replace them, this might be a good time to do so. (IMG:style_emoticons/default/shades.gif) |
| brant |
Dec 23 2011, 12:14 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,297 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
once upon a time, I took my car for a errand...
came out after 20 minutes and the washer fluid was still squirting under pressure from the crack in the hose. Spraying up under the dash and making a huge mess. (spare tire air pressure was not flat yet) my tach was half full of washer fluid and it was sloshing from side to side behind the lense as I drove home. you've got to pull the column open and get to those hoses (tubing really) where they connect to the column mounted switch... a poor design compaired to electric washer pumps. brant |
| DRPHIL914 |
Dec 23 2011, 12:18 PM
If the hoses haven't been used in a while, they're probably rotten. I've seen that many times. It's not that hard to replace them, this might be a good time to do so. (IMG:style_emoticons/default/shades.gif) Thanks. Its under the dash it came off at the column switch I guess. How do you access that? Do I pull the gauge cluster, ? What size hose is it? Phil |
| SLITS |
Dec 23 2011, 12:20 PM
I had a supply of Nippondenso electric windshield washer kits ... Reservoir with pump mounted on it and tubing to connect to washer nozzles ... all you need was a momentary switch on the dash
| SLITS |
Dec 23 2011, 12:22 PM
If the hoses haven't been used in a while, they're probably rotten. I've seen that many times. It's not that hard to replace them, this might be a good time to do so. (IMG:style_emoticons/default/shades.gif) Thanks. Its under the dash it came off at the column switch I guess. How do you access that? Do I pull the gauge cluster, ? What size hose is it? Phil You have to pull the steering wheel and the switch assemblies ... there is a two pronged fitting on the back of the switch that the hoses connect to. I'll try to find a pic .......... |
| SirAndy |
Dec 23 2011, 12:23 PM
I had a supply of Nippondenso electric windshield washer kits ... Reservoir with pump mounted on it and tubing to connect to washer nozzles ... all you need was a momentary switch on the dash (IMG:style_emoticons/default/agree.gif) I used a 911 electric pump and slightly modified stock reservoir. http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/bye1.gif) |
| SLITS |
Dec 23 2011, 12:55 PM
Maybe you can get to them without taking the steering column apart ....
(IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1324666529.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1324666530.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1324666530.3.jpg) Knock yerself out ............ |
| Drums66 |
Dec 23 2011, 02:41 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Maybe you can get to them without taking the steering column apart .... Knock yerself out ............ ........Its doable without taking column apart....I just eliminated mine (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/bye1.gif)(hands on window washer) |
| DRPHIL914 |
Dec 30 2011, 10:13 PM
Maybe you can get to them without taking the steering column apart .... (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1324666529.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1324666530.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1324666530.3.jpg) Knock yerself out ............ Hwy slits, I got a better look at this today. , had my tank pulled and replaced the air box and got that working., the took a look at the back of the column from under the dash. I see the 2car plastic barbed connectors. One should be an in, the other an out, right? Which is which. I have no hose hooked to either. I k ow where the incoming hose os, it was squirting the floor. But I don't see the hose that should be going out to the squirter. Does anyone have a diagram of hog this all connects? Phil. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 25th November 2026 - 02:14 AM |
