| Mueller |
Aug 25 2004, 03:24 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
has anyone else found that the greenish CV bolts are soft???
I've had a few break while I was installing them and they snapped well under 20 lb's of torque (I tighten them using a torque wrench, I start off with a lower setting and work my way up to the proper setting) I've never had a problem with the darker black colored CV bolts which I am guessing are factory spec and not just the generic VW bug replacment units????? (picture "borrowed" from another thread (IMG:style_emoticons/default/smile.gif) ) Attached image(s)
| machina |
Aug 25 2004, 03:35 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Got these from EBS, (engine builders supply)
Says they are factory part #893 407 237 as per the parts catalog. They did seem kind of soft though. Think I should use the old black ones after all this drilling? dr |
| echocanyons |
Aug 25 2004, 03:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,115 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
I got a pair from EBS that had the greenish look to them, I used these for my caliper mounts and they came in a porsche factory labeled sealed bag.
I havent tried to torque them though. Should I be worried? |
| 736conver |
Aug 25 2004, 04:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Other differences I have notice. The greenish/silver ones are longer, less threads and have a bigger head on them
| machina |
Aug 25 2004, 04:12 PM
Isn't most of the torque load carried by the short steel pins that locate the CV's and not the bolts themselves?
dr |
| Allan |
Aug 25 2004, 04:14 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Where can you get the black hardened ones?
| TimT |
Aug 25 2004, 04:25 PM
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE Where can you get the black hardened ones? Maryland Metrics McMaster Carr Ask for grade 10.9 I think, or the highest grade available |
| Allan |
Aug 25 2004, 04:28 PM
What do I tell them? Will they know if I just say CV bolts for a 914? I don't know the specifics of the bolts, dia., thread, length, etc.
| Mueller |
Aug 25 2004, 04:35 PM
QUOTE Will they know if I just say CV bolts for a 914? hahahaha...chances are they won't know what a 914 is (IMG:style_emoticons/default/smile.gif) I don't have the specs here, but if you plan on working on your car a bunch in the future, it's a good idea to learn about hardware.....pick up the Machnery's Handbook (even an old copy from eBay is great to have) and start learning (IMG:style_emoticons/default/wacko.gif) |
| GWN7 |
Aug 25 2004, 04:49 PM
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Isn't there a grade rating on them? Should be on the head somewhere...
| machina |
Its an M8 x 45...
dr |
| machina |
Aug 25 2004, 04:52 PM
QUOTE(GWN7 @ Aug 25 2004, 06:49 PM) Is't there a grade rating on them? Should be on the head somewhere... There are 2 little dots right next to each other on the head, (on the top face)... dr I have also bought porsche factory hardware in Factory packaging that have this greenish tint. Are we getting to anal about this? I got too many things on my list right now. dr |
| 736conver |
Aug 25 2004, 04:59 PM
The black bolts I have are 12.9.
The silver ones just have two raised dots |
| TimT |
Aug 25 2004, 05:26 PM
Didnt someone recently post about flywheel bolts that he bought from mittlemotor, that turned out to be cheap 3rd worlds knock offs? Those greenish bolts look suspect to me... look at the pic posted above, the black oxide bolt looks well machined with nice tolerances, the other bolt looks cheap..
They can both be equaly as strong though, and 20 ft/lbs doesnt make alot of tension in a bolt.. |
| TimT |
Aug 25 2004, 05:27 PM
Im a bolt geek LOL
the on on the left has nice radii where the shank on the bolt meets the head, and the root of the thread appears to be rolled no cut... |
| TimT |
Aug 25 2004, 05:30 PM
The bolt on the right looks like a cheesy knock off... cut threads, no radius from the shank to the head..
sorry for taking three posts to say this LOL |
| Verruckt |
Aug 25 2004, 05:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
QUOTE(Mueller @ Aug 25 2004, 02:35 PM) I don't have the specs here, but if you plan on working on your car a bunch in the future, it's a good idea to learn about hardware.....pick up the Machnery's Handbook (even an old copy from eBay is great to have) and start learning (IMG:style_emoticons/default/wacko.gif) When I was working as a toolmaker, the last company I worked for flat out asked me in the interview if I had my own copy of Machinery's Handbook. (IMG:style_emoticons/default/laugh.gif) That book is awesome. |
| Mark Henry |
Aug 26 2004, 06:51 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
QUOTE(TimT @ Aug 25 2004, 07:26 PM) Didnt someone recently post about flywheel bolts that he bought from mittlemotor, that turned out to be cheap 3rd worlds knock offs? Those greenish bolts look suspect to me... look at the pic posted above, the black oxide bolt looks well machined with nice tolerances, the other bolt looks cheap.. They can both be equaly as strong though, and 20 ft/lbs doesnt make alot of tension in a bolt.. I bet they're made in China or somewhere like that. There's a total influx of cheap and counterfit hardware coming in from the third world. The counterfit ones have a grade on them and they don't even come close to it. Crap like this has even been put on aircraft by mistake. (IMG:style_emoticons/default/unsure.gif) I get Lobro boots for the bugs and they come with German bolts and CV grease. |
| thomasotten |
Aug 26 2004, 07:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,572 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Wait a minute... I bought some CV boot repair kits from Tweeks. They were German made, and they had those green bolts in them. They must be German.
I also ordered some bolts seperately from Tweeks at the same time, not knowing the kits came with bolts, and they sent black bolts, but they were the allen head. Not the star head. What cars are those from? Now I don't know what to use. (IMG:style_emoticons/default/confused24.gif) |
| DonTraver |
Aug 26 2004, 08:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
When I want to be sure that the bolts, hardware are up to spec. I go to the local Caterpillar Dealer.
The quality is always good, I've been to their Metalurgy lab in Indiana, and the prices are very resonable, and their dealers are all over the place. Another good thing is they will sell you 1 bolt/nut, some places want you to buy a complete box, etc. I tested some of their bolts when I was taking a Metalurgy course. They all exceded specs. If you go to Caterpillar, pick up the book (free) "One good Source", it lists all the nuts, bolts, washers, hardware, etc with part numbers. Then you can call your order in, cool. |
Lo-Fi Version | Time is now: 18th March 2026 - 04:35 AM |
