nynone4 |
Hammer to fit. Paint to match. ![]() ![]() Group: Members Posts: 353 Joined: 20-May 03 From: East Peoria, Illinois Member No.: 713 Region Association: None ![]() |
The Triad exhaust that was on the car was beginning to come apart internally, so I replaced it with another fairly low restriction alternative. Bought two 10" Supertrapps and had the local muffler guru weld up some pipes and flanges so it's an easy on / off affair if the boys in blue give me too much hassle. It's not too bad at idle (has a nice gallop and sputter), but it's LOUD under even just a little throttle and flat out HOWLS when you cram it to the floor.
Pure music!!! Here's some Pics (I haven't gotten the short valance for it yet): Attached image(s) ![]() |
nynone4 |
Let's try that again:
nynone4 |
KHKJH
nynone4 |
JGKHJJHG
nynone4 |
MVMJHVG
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Those are the stainless shorty muffs....I use the longer ones on 3.6 and have used the regular mild steell ones on the 3.0.
Depending on CIS or Carbs, they like a little backpressure and removing some of the discs, quiets them a bit and will help on bottom torque. |
nynone4 |
Thanks for the tip Mike - I've got them down to 9 discs each right now (on a carbed 2.7 RS spec motor). Seems to be happy there - but I'd like to get it onto a dyno to see what the optimum setup is as far as discs go.
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
I had them on my car, I think they are great mufflers. For LOUD tracks, I just pull the guts out and have instant megaphones, then for other tracks I run 18 discs, then for quiet tracks I run 6-8 discs. Yes you can feel the loss of power when you run few discs...
Mine were kinda (I have steel ones) ratty though, so I recently replaced them with this set up I made (mufflers are Coast) Attached image(s) ![]() |
TimT |
BTW for those quiet track i keep the supertraps in my trailer, just a few minutes to put them back on.
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
TimT... can you post a sound clip?
I can host it for you. Regards, Karl |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
Quarl wants to know how his mufflers will sound (IMG:style_emoticons/default/biggrin.gif)
drew365 |
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 ![]() |
I've been running 18 disks on mine. Really loud. I just set them up with 6 disks for this weekends track date which is at a short tight course. I haven't run them with only 6 so I hope I didn't go too far.
I would suggest you make a hanger to hold some of the weight of the muffler otherwise I think you will be splitting your welds at the flanges. |
Qarl |
I have a clip (but not good) from a 911.
Just wanting a mid-engine sound clip... Should be the same... just hoping for a better quality clip. (IMG:style_emoticons/default/beer.gif) |
TimT |
Karl Im going to Watkins Glen tomorrow, Ill throw the cam in the car for a few sessions..
You will hear alot of intake noise though LOL BTW I can host video the website in my sig was made by me and is maintiained by me... (I know, I still use frames on the site and havent really updated it in awhile) |
d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
I have a flim clip going through the esses at Road atlanta and one on the straight sound is ok at best. Ill try to figure out how to get it to you. 2.5-6 with megaphones.
Joe Bob |
QUOTE(drew365 @ Aug 30 2004, 04:21 PM) I've been running 18 disks on mine. Really loud. I just set them up with 6 disks for this weekends track date which is at a short tight course. I haven't run them with only 6 so I hope I didn't go too far. I would suggest you make a hanger to hold some of the weight of the muffler otherwise I think you will be splitting your welds at the flanges. I run 18 as well..but I have twin sport cats up stream....need it for the smog on my 83....Manfred is getting a new muff for the street so we can tune it..... |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
Andy - have you found that a little more backpressure/midrange torque is noticably better at the Streets? I was debating whether to swap for the megaphones this weekend (vs. the 2in/2out sport muffler).
With the stock 914 gears I know I was better off with the muffler as it would bog in a few spots with the megaphones. But with short gears I am not so sure which is better on that track. For the big track the open pipes rev significantly quicker/stronger. |
campbellcj |
Well I think I just answered my own question, for September at least. I am getting tired of swapping exhausts and since the G.A.F. is 9/11 I think I'll just leave the muffler on. Then prior to OTR at WSIR on 9/22 I'll go to the megaphones.
I would really like to learn more about the Burns/Coast and Phase9 options so I could make full power whilst having a semi-streetable noise level. |
drew365 |
I haven't experimented with fewer disks at the Streets yet. This will be my first, I'm hoping I didn't take too many out and leave myself no top end but we'll see Sunday. I put on very restrictive mufflers for Laguna Seca and the car ran great so I'm going to start playing with different disk counts at different tracks.Should help to make setup even more confusing. (IMG:style_emoticons/default/wacko.gif)
campbellcj |
How quick & easy is it to swap discs on the Supertrapps? Do they cool down quickly i.e. if you come off a session can you (safely) mess with them by your next session?
Frank Beck in AZ is now making a trick 914-6 race exhaust that is interesting too and supposedly makes huge power...but I suspect it is north of $2 large |
Lo-Fi Version | Time is now: 10th June 2024 - 11:16 AM |
