Rear window install, What size |
glens67 |
Apr 13 2012, 01:19 PM
Newbie Group: Members Posts: 35 Joined: 13-March 10 From: Middleton, ID Member No.: 11,462 Region Association: Rocky Mountains |
Do I use 1/4", 5/16" or 3/8" Butyl
What is the thickness of the 2 rubber Support strips? The Butyl tape that I removed was compressed To 3/16" and squished to just over 5/16", which leads me to thinking that it was 1/4". Eric Shea's write up indicates a NAPA part # 4169 which is 3/8" wide. Other how-tos indicated 3 sizes above. Thanks Glen (IMG:style_emoticons/default/beer3.gif) |
Valy |
Apr 13 2012, 01:43 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Do I use 1/4", 5/16" or 3/8" Butyl What is the thickness of the 2 rubber Support strips? The Butyl tape that I removed was compressed To 3/16" and squished to just over 5/16", which leads me to thinking that it was 1/4". Eric Shea's write up indicates a NAPA part # 4169 which is 3/8" wide. Other how-tos indicated 3 sizes above. Thanks Glen (IMG:style_emoticons/default/beer3.gif) I used 3M 5/16 butyl tape. I remember the book (don't remember which one) was talking about 8mm that is about 5/16. Regarding the rubber supports, they are there just to locate the window in the frame and absorb vibrations. The glass should not contact the lower metal lip of the frame or it will brake from vibrations. I used the rubber blocks that came with the butyl tape. They were about 1/8-2/8. Just make sure the window is in place and doesn't touch the lower frame. |
McMark |
Apr 13 2012, 05:00 PM
Yup, factory manual specs 8mm.
Black914_4 |
Apr 13 2012, 05:09 PM
Member Group: Members Posts: 272 Joined: 11-January 12 From: AR Member No.: 13,994 Region Association: South East States |
I tried to do mine last week. Used 3/8 from local parts store. I tried it twice and neither time worked very well for me. There was spots that didn't stick very well.
Part of the problem might have been when I stuck the tape to the metal I pressed too hard, so when I stuck the glass to the tape there was gaps. When you stick the tape to the metal frame don't push on it very hard. Let the glass push the tape into the metal. Might save you some trouble. |
mrbubblehead |
Apr 13 2012, 05:15 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i agree with valy and mark 5/16. i used 3m window weld from local auto paint supply shop...
underthetire |
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I used 5/16 as well.
glens67 |
Apr 13 2012, 05:37 PM
THANKS!!!
5/16" on order |
rfuerst911sc |
Apr 14 2012, 04:22 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Another option is to install it with urethane adhesive like all modern cars are done. Had a pro install my windshield and rear window this way. Unless they break I'll never have to worry about leaks.
bperry |
Apr 14 2012, 09:10 AM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Lo-Fi Version | Time is now: 8th June 2024 - 11:27 PM |
