911 Centre Mount Brake, What year is the best to use in converting to a Centre mount set up |
NS914 |
Nov 26 2012, 07:28 PM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Hey Guys, I did some searching and have not found it yet but one or some of us have done this. I am replacing the front floor panel and installing my Engman Long kit and thought "I may as well". Can you direct me to who and what they used for the conversion. Is any year better than another. Thanks as always!
SirAndy |
Nov 26 2012, 07:36 PM
Resident German Group: Admin Posts: 41,670 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Not sure this project was ever finished: (IMG:style_emoticons/default/confused24.gif)
http://www.914world.com/bbs2/index.php?showtopic=111321 964 handbrake: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1284916615.4.jpg) |
John |
Nov 26 2012, 10:40 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Do a Google Search for Armando Serrano 914 GT and then find a reference to "The 914/6 GT Project".
Way down deep you will find where he duplicated factory mods where they used a 911 style parking brake lever between the seats as you are referring to. Not the most well planned idea as the cables have nowhere to go except into hot exhausts..... I prefer the factory routing of E-Brake cables, but that's just me. This is a picture of the former Miles Collier original 914/6 GT. |
moparrob |
Nov 28 2012, 11:45 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
My car is the 'unfinished' one in the post above. However I wish I had seen Jeff's install before I did mine.
This is what you are looking for: (IMG:http://www.914world.com/bbs2/uploads/post-7712-1230799928.jpg) http://www.914world.com/bbs2/index.php?sho...6791&st=380 This was my thread: http://www.914world.com/bbs2/index.php?sho...=111321&hl= (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1354167905.1.jpg) I ended up having to fabricate cables from scratch - major PITA. Jeff's is much better as he uses stock (passenger side) cables and his mounting bracket allows greater flexibility in attachment options. |
matthepcat |
Nov 29 2012, 12:25 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Couldn't you just run a line lock to the rear brakes and make it e-brake handle activated?
Mike Bellis |
Nov 29 2012, 12:45 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
NS914 |
Jan 21 2013, 12:27 PM
Couldn't you just run a line lock to the rear brakes and make it e-brake handle activated? Does not work well when the fluid cools down... Ask me how I know. The fluid contracts when cold and will loosen the hold. Guys, Thanks again for the follow up....way better than me! I got distracted from the 914 but am back at it again. I am welding my new floor panel from Restoration Design adn fixing some Rocker Panel issues as well. Once all that is done, I will get my long kit installed as well. I have a busy winter ahead of me. Grant |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:39 AM |
