| markyb |
Dec 15 2012, 12:00 PM
Member ![]() ![]() Group: Members Posts: 100 Joined: 27-November 11 From: Rochester, Michigan Member No.: 13,823 Region Association: None |
| Krieger |
Dec 15 2012, 12:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,900 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
I do not think that is the thermo time. That would be on the base of the plenum.
| jimkelly |
Dec 15 2012, 12:12 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
| markyb |
Dec 15 2012, 12:13 PM
I had a Pertronix installed maybe the old lead to the distributor? I can't trace it since it tucks behind the firewall mat and is wrapped with the factory binding tape. It looks like an inline relay of some sort? I can do a lot of mechanical stuff, but reading the schematic is giving me a bit'o trouble...
| markyb |
Dec 15 2012, 12:34 PM
I traced it down and see that it joins up with a second wire fed down through the engine tin. This is an A/C car and it's currently disconnected, judging by the size of the wire and the inline relay, I'll bet it has something to do with that. Thanks for the effort, I thought that I was on to something bigger....if it isn't that, as Arnold would say, I'll be bak!
| dlee6204 |
Dec 15 2012, 02:55 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I traced it down and see that it joins up with a second wire fed down through the engine tin. This is an A/C car and it's currently disconnected, judging by the size of the wire and the inline relay, I'll bet it has something to do with that. Thanks for the effort, I thought that I was on to something bigger....if it isn't that, as Arnold would say, I'll be bak! You are correct. It's for the A/C Unit. |
| markyb |
Dec 15 2012, 06:37 PM
I traced it down and see that it joins up with a second wire fed down through the engine tin. This is an A/C car and it's currently disconnected, judging by the size of the wire and the inline relay, I'll bet it has something to do with that. Thanks for the effort, I thought that I was on to something bigger....if it isn't that, as Arnold would say, I'll be bak! You are correct. It's for the A/C Unit. Thanks dlee, at least I won't have to hunt for those wires when I put the a/c back in service next spring! I would suspect that those are the trigger wires for the compressor, I have a bit of research to do this winter on which parts I'll use for the new system, originally a VPC unit. I've been saving up lots of info and suggestions from the "Garage" prior posts. And thanks to all others for the suggestions. I showed this forum to a friend that owns an old Mercedes , he couldn't believe the camaraderie and quick responses to technical issues of other members (other than the battle going on with the dude and his "first look at a 914" post (IMG:style_emoticons/default/lol-2.gif) ) |
| dlee6204 |
Dec 15 2012, 09:11 PM
Thanks dlee, at least I won't have to hunt for those wires when I put the a/c back in service next spring! I would suspect that those are the trigger wires for the compressor, I have a bit of research to do this winter on which parts I'll use for the new system, originally a VPC unit. I've been saving up lots of info and suggestions from the "Garage" prior posts. Have you seen this thread? It also has a VPC wiring diagram... (IMG:style_emoticons/default/smile.gif) http://www.914world.com/bbs2/index.php?showtopic=192917 |
| markyb |
Dec 16 2012, 07:14 PM
I'm not sure how I missed that post, but you saved me a lot of work by pointing it out! I have to read it later when I have some free time. From some older posts I remember that there is an adapter bracket sold by Bus Depot that will allow me to put the Sanden unit on my York mount.
Thanks again |
Lo-Fi Version | Time is now: 17th November 2026 - 04:33 PM |
