A Arm Rebuild, Bushings and ball joint |
jrrhdmust |
Jul 8 2013, 03:00 PM
Senior Member Group: Members Posts: 1,402 Joined: 12-October 11 From: Alabama Member No.: 13,668 Region Association: None |
So I thought I would write of my escapades this weekend. I continued on with the front suspension rebuild. This time is was the A arms.
I ordered the special tool to install the ball joints, although I had a little difficulty trying to use the chisel method to loosen them. I ended up soaking them in WD40 and using the install tool with an electric impact wrench and they came right off. The bushings were a different story = mostly user error. So I bought the URO bushings to replace the originals. I have a little Harbor Freight chepo press. I heated them up like the instructions said, however my first effort I was right at the bottom of 180 degrees. Secondly I took the dish soap and lubed both parts as opposed to just one, and lastly I spent an inordinate amount of time setting the press - which probably let them cool further. Lastly, I bent the little ears on the main A arm trying to force the bushing in. So I pressed the bushings out, pressed the little ears back into place, and reread the instructions. The second time, I made sure my press was ready for action, and I used a block of wood using the length of the A Arm to press against, instead of the little ears. Secondly, I heated the rubber to 190 to 200, as opposed the 180-200, and I only lubed the main shaft. I made haste to the press (which is in the basement, as opposed to my kitchen), and the bushings pressed on without a hitch. Hope this helps someone avoid my mistakes. |
andys |
Jul 8 2013, 03:08 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
If I recall correctly, the URO instructional video says to put bushings in boiling water. That's how I did mine (and the soap), and they went on without a hitch.
Andys |
Retread |
Jul 9 2013, 02:04 PM
Newbie Group: Members Posts: 26 Joined: 5-March 06 Member No.: 5,672 |
The Ball Joint tool that I have came from Baum Tools. The instructions specifically state it is for tighten / torquing only. Not to be used for loosening.
Use a pipe wrench to loosen the Ball Joint sleeve nut. Replace both sleeves if scratches offend you. Trade your WD-40 in on AeroKroil from Kano Labs (found on the internet). |
dknechtly |
Jan 21 2016, 01:01 PM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
I see you used the URO bushings. I'm torn between Elephant rubber, Rebel, and URO. Are these still performing OK? I'm pretty much planning on rubber since mine is a pure street car.
Mark Henry |
Jan 21 2016, 01:14 PM
JmuRiz |
Jan 21 2016, 01:19 PM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
If you go rubber, go with the Elephant.
jmill |
Jan 21 2016, 04:18 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
If you go with bushings check out Rebel Racing. I have their RSR set up.
http://www.914world.com/bbs2/index.php?showtopic=273707 |
Lo-Fi Version | Time is now: 7th June 2024 - 07:13 PM |
