Headlight assemblies completed, finally getting a little garage time in |
Doug Leggins |
Dec 4 2004, 07:22 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I've been working on the house remodel alot lately. But have been able to get out to the garage some evenings. Was able to get the headlights put together.
I started with 4 sets of headlights and picked the best parts from the batch to get the best set that I could. A huge transformation from parts like in this pic. These are some of the pieces that did not make the cut. Attached image(s) |
Doug Leggins |
Dec 4 2004, 07:26 PM
The sandblasting and powder coating of the buckets turned out great on these parts.
Spent a lot of time cleaning up all of the little pieces. Found out that laquer thinner takes ziebart coating right off of parts. Attached image(s) |
Doug Leggins |
Dec 4 2004, 07:28 PM
Had 1 good set of H4 headlights. Cleaned them up and the chrome rings.
Attached image(s) |
Doug Leggins |
Dec 4 2004, 07:29 PM
The side that will pretty much never be seen.
Attached image(s) |
michel richard |
Dec 4 2004, 07:34 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
Nice,
It's fun to see pieces like that come together. Michel Richard |
mattillac |
Dec 4 2004, 07:35 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
looks great (IMG:style_emoticons/default/clap56.gif) what'd you use to touch up the black plastic trim? (IMG:style_emoticons/default/smilie_pokal.gif)
Doug Leggins |
Attached image(s) |
Doug Leggins |
Dec 4 2004, 07:48 PM
I painted the surrounds with krylon Fusion paint. This is the first time that I have used the Fusion paint - so far it looks very good.
I have also painted the fresh air box assembly with this paint. I'll post pics of it when I get it finished. I had one air box done and then broke off one of the drain legs (IMG:style_emoticons/default/headbang.gif) So now I'm painting a second box. |
Lo-Fi Version | Time is now: 5th June 2024 - 12:16 PM |
