brakes, Brakes and BRAKES, Bigger is better |
Bigbohr |
Dec 17 2004, 05:37 PM
Superlurker Group: Members Posts: 224 Joined: 19-September 03 From: Houston, TX Member No.: 1,176 |
The size difference was so striking that I had to post a pic ...
On the left is a 914 front caliper, in the middle a 911SC front caliper and on the right a 944 Turbo front caliper. The 944 caliper can be modified to fit 911 struts. Despite its larger size, the 944 caliper seems to weigh significantly less than the 911 A caliper. I guess an S caliper may be lighter. Other advantage of the 944 caliper is that it is a 4 piston design. Attached image(s) |
Rough_Rider |
Dec 17 2004, 05:44 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
Yep i weighed a full set of 4 944T calipers & their pounds lighter than the stock 914 items. Although the new rotors are bigger so negate the weight advantage.
When you fit yours could you jot down what parts you used. I'm currently scavenging parts together & double checking what to use. |
Mueller |
Dec 17 2004, 05:47 PM
QUOTE so negate the weight advantage ....it's even worse that the additional weight is rotating (IMG:style_emoticons/default/smile.gif)still gotta love big brakes, not sure why they are so darn sexy (IMG:style_emoticons/default/wub.gif) |
Aaron Cox |
Dec 17 2004, 07:45 PM
do they fit 3" or 3.5" strut spacing?
Bigbohr |
Dec 17 2004, 08:11 PM
They work on the 3.5" spacing struts. The 944 mounting eyes spacing is a bit larger than 3.5". Need to machine the eyes slightly to make the caliper fit on 911 struts.
Gary |
Dec 17 2004, 08:29 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Have 911 struts modified to fit 944T calipers on my machine. There's pictures on this thread: Gary's 914. Wes Hildreth through Rich Johnson modified the mounting ears. Modifying the calipers is an option too... Stops on a dime. Installed a 19mm MC and replaced the proportioning valve with a T fitting. Now going with 911 carrera rear calipers with 911 ebrake setup too. Since that thread, Steve at Aircooled Racing has replaced the rotors and pads. Within a month or two of finishing....
ein 6er |
Dec 17 2004, 08:33 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
QUOTE(Mueller @ Dec 17 2004, 03:47 PM) QUOTE so negate the weight advantage ....it's even worse that the additional weight is rotating (IMG:style_emoticons/default/smile.gif)still gotta love big brakes, not sure why they are so darn sexy (IMG:style_emoticons/default/wub.gif) i saw one of those new car shows, i think it "tuner tv" or something. they had been doing a series of performance mods to a honda and doing before and after runs on a dyno to see what sort of hp increase they would get. on this show they did an exhaust upgrade and a big brake kit. the new exhaust was suppose to give them X amount of an hp increase. but on the dyno, they were actually making less hp than with the stock exhaust. they said, the the reason they were making less hp after the mod, was because of the rotating mass of the larger rotors. |
echocanyons |
Dec 17 2004, 08:43 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I weighed my stock 914 struts/brake and my 911 struts with monoblocks (both struts fully loaded and ready for a wheel) and the difference was ~41lbs for stock and ~40 for the monoblocks I state "~" because I was using a home scale and question the accuracy but the point is that the weight was pretty much the same for stock vs. upgraded in my case.
charlesmac |
Dec 17 2004, 10:43 PM
Member Group: Members Posts: 210 Joined: 27-June 04 From: Richland, MS Member No.: 2,264 |
I saw that same episode of 'whatever the the name of it is'. I remember them saying that the bigger rotor was lighter than the factory one, but because of the larger diameter, they lost h.p. at the wheels.
John |
Dec 17 2004, 11:15 PM
What is the difference between 930 calipers and those from that front engined water pumper?
The real key to AWESOME braking is the ability to dissipate the heat generated during braking. Larger calipers will only add more heat given the same rotor size. What is the size of the rotors? |
seanery |
Dec 18 2004, 07:06 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
If I remember correctly this is what I've got on bluecar:
FRONT: 944 Turbo front calipers on 911S Bilstein struts Carrera Front Rotors REAR: Boxster monobloc rear calipers Rich Johnson adapters 911 SC Rear Rotors Weltmeister adjustable Prop valve |
Gary |
Dec 18 2004, 10:07 AM
QUOTE(seanery @ Dec 18 2004, 05:06 AM) If I remember correctly this is what I've got on bluecar: FRONT: 944 Turbo front calipers on 911S Bilstein struts Carrera Front Rotors REAR: Boxster monobloc rear calipers Rich Johnson adapters 911 SC Rear Rotors Weltmeister adjustable Prop valve Sounds a lot like mine: Carrera rotors all around, 944T calipers up front, carerra calipers out back. Might look into those monoblocks sometime. I suspect I'd save a few pounds... |
Bigbohr |
Dec 18 2004, 09:53 PM
QUOTE(JOHNMAN @ Dec 17 2004, 09:15 PM) What is the size of the rotors? 944 turbo rotor measures 298x28 and 930 rotor 304x32. 911SC front rotors measure 282x20. The 944 turbo and 930 brake pads are the same. I tried to measure/estimate the brake surface area as good as I could (pads are not square). 944T/930 brake pad surface is slightly less than 7 sq in. 911SC pad surface is about 5.5 sq in. |
sixnotfour |
Dec 18 2004, 10:16 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
The carrera rotors are thicker ; front 24mm ,rear 42mm ,same dia. as SC.
brant |
Dec 19 2004, 12:39 PM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
QUOTE(echocanyons @ Dec 17 2004, 07:43 PM) I weighed my stock 914 struts/brake and my 911 struts with monoblocks (both struts fully loaded and ready for a wheel) and the difference was ~41lbs for stock and ~40 for the monoblocks I state "~" because I was using a home scale and question the accuracy but the point is that the weight was pretty much the same for stock vs. upgraded in my case. did that include the rotors? I know you said fully loaded.... but I would think the difference between a small non vented rotor, and a large vented rotor would be closer to 10-15lbs.... brant |
echocanyons |
Dec 19 2004, 12:56 PM
Yep that included rotors.
Kelly |
brant |
Dec 19 2004, 01:01 PM
wow...
brant |
datapace |
Dec 21 2004, 12:42 PM
Member Group: Members Posts: 133 Joined: 19-January 04 From: Atlanta, GA Member No.: 1,579 Region Association: South East States |
Hey you 944T front caliper guys ... are you using parts from a particular year, or are the 951 calipers all the same?
How many of you modified the strut housing vs. the caliper ears? thanks, -bryan |
iamchappy |
Dec 21 2004, 12:55 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Mine are hogged out, They came that way when I purchased the car. I have read by others that it is not a good way of doing it, but many have done it this way without problems, My car was a track car and used the calipers mounted this way without problems. I converted it back to a street car and the brakes work great, Im not to worried about it. But think the correct way is best via the ears or modifiing the mounts on the struts.
Attached image(s) |
seanery |
the 86 non ABS calipers are the ones.
I elongated the holes a tiny little bit. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:12 PM |
