RickS |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None ![]() |
Was on a spirited drive with my pals on the back roads in the Seattle area (Black Diamond, Flaming geyser, Enumclaw) when I went to downshift - felt a something give way when I put the clutch in and then couldn't find any gears. The shift lever would barely move in the 2/3 plane.
Coasted to a stop and pulled the center plastic tunnel cover into a conveniently cut rectangular hole in the tunnel. When I pressed the clutch in the fuel line would move back and forth. When I pressed the fuel line down with my finger I could hit most of the gears. The fuel line bracket had broken inside the tunnel and was interfering with the gear shift linkage. Between the three of us, I concocted a wedge to press the fuel line down so at least I could hit 2/3/4 with some effort. The wedge was a roll of electrical tape with a 15mm socket taped inside. Some time the next day a sleeve was made which secured the errant line and held in safely in place and out of the way of the linkage. The sleeve was made of an aluminum block - center drilled to accept the line, drilled on both ends to accept a couple of bolts, and then cut in half prior to install. After the block was secured around the line, It was bolted to the floor pan through the drilled ends. And now it shifts better than ever - the line must have been interfering for a long time - which pressed against the bracket and caused it to fail. The end. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,438 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
I think you mean "Clutch Tube"
RickS |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,175 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
The fact that thep clutch pedal moved the fuel ines is odd to say the least. The clutch cable should be sheathed almost all of the way in a rigid tube held to thebody. Cann you tell us how the fuel line got in the way. Is it possible that by holding down the fuel lines you mitigated a failed clutch tube anchor point?
RickS |
check the splines on the inner shift rod where they connect to the shifter. You may have changed the adjustment hence the difficulty finding gears it only takes a few mm for it to be out of adjustment. Also check the firewall bushing and two cone screws on the shift rod It actually shifts far better now without the previous binding - which is a great thing. Good data points for the future though. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I think what everyone is confused about is that the fuel lines are 40 year old plastic.
QUOTE the line must have been interfering for a long time If either one of them was rubbing on your shift rod enough for you to notice then it probably would have worn through them very quickly. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Stock fuel lines thru the tunnel are plastic and are not held in with brackets.
Clutch tube is metal and held in by brackets. (IMG:style_emoticons/default/confused24.gif) |
Cap'n Krusty |
..........and the fuel lines are far to the right, the clutch and throttle tubes are to the left.
The Cap'n |
sixnotfour |
Attached thumbnail(s) ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Stock fuel lines thru the tunnel are plastic and are not held in with brackets. Clutch tube is metal and held in by brackets. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/agree.gif) but it probably wouldn't be a bad idea to look at the other side of the tunnel and see if you have SS fuel lines or the origional plastic. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:00 AM |
