911 901 gate shifter -, will this work on a teener? |
Aaron Cox |
Jan 10 2005, 07:10 PM
says it works on 911 901's.... whats the dilly on this gate shifter? Gate Shifter
TimT |
Jan 10 2005, 07:15 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
that works on the 915 style shift tower. to use it you need to modify and install the 915 tower to work with a 901 (they have different shift patterns)
MattR |
Jan 10 2005, 07:18 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
So the 915 shifter will work on both the side shift and tail shift? With modification... of course.
Jeroen |
Jan 10 2005, 07:19 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
people on the bird-board claim it works...
dunno, prolly does, but it looks like a DIY hackjob to me plus, you'd need a 915 shifter housing When time comes, I'm just gonna get me a RennShifter (new revised version coming soon) and be done with it |
MattR |
Jan 10 2005, 07:28 PM
The guy who makes that kit is a friend of mine... I can assure you its not a hack job. His 69 RS conversion is BEAUTIFUL.
This is $150 plus a 915 shifter. The RennShift is a lot more. I think this is a less expensive alternative. |
Mueller |
Jan 10 2005, 07:47 PM
the "hose clamp" kinda adds to the perception.....never heard anything wrong with the kits, but I don't follow the 911 stuff too much.... |
MattR |
Jan 10 2005, 07:49 PM
Mike, that looks like a prototype.
(IMG:http://www.seinesystems.com/Images/GateShift-1st-1.jpg) thats the one I saw. |
736conver |
Jan 11 2005, 12:20 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
I had this on my 73 911 I had. It was the more expensive one not the one with the hose clamps. It work pretty decent and it was easy to install. I never had a problem going into the wrong gear after it was installed.
Dont know how well it would work on a teener though. |
skline |
Jan 11 2005, 01:02 AM
Aaron, just get yourself a Rennshifter and be done with it. No looking everywhere trying to find all the right parts. The hassle alone is worth it.
Jeroen |
Jan 11 2005, 08:00 AM
I didn't say it IS a hack job, I said it LOOKS like it... Just a little to crude for my taste And like I mentioned, I never heard anything bad about it About the hoseclamp... IIRC, that's only used to fit the parts you're supposed to weld the tabs to the shift stick (like the second pic shows) |
John |
Jan 11 2005, 11:32 AM
I don't know if those work with 901 gearboxes in 914's, but they sure work well with 915 boxes in 914's. That is the setup I run. (the link above says it works with the 901)
Did anyone download that 500MB PDF file?
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) That is what you are supposed to to when everything is aligned correctly. It works like it is supposed to. The mod for 901/914's that I saw was simply a reverse-first lockout where a pin would fall in the way preventing the user from selecting that gate. |
greglepore |
Nov 5 2005, 09:41 PM
Newbie Group: Members Posts: 18 Joined: 24-March 05 From: S/E Pa Member No.: 3,808 |
The Seine shifter, fwiw, works great on a 911 w/ 901 or 915. It is a major pain to adapt a 915 housing to a sideshift 901, as you need to cut the eye off the 901 shift rod and tig it to the 915 rod at just the right depth-ie accounting for the fact that the 915 housing sits higher. No fun, took me almost 2 full days to get it done.
TimT |
Nov 5 2005, 11:41 PM
Say what?
the seine shift is still a hack job, always has been, and always will be seine shift does work though hose clamps sheesh RENNSHIFT |
Aaron Cox |
Nov 5 2005, 11:43 PM
year old post.....
since i have bought a rennshift and am uber satisfied |
Lo-Fi Version | Time is now: 8th June 2024 - 06:48 AM |
