I am thinking about being rash! |
Bleyseng |
Feb 26 2005, 08:36 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Picked up a 2.4l six today and maybe this one has found a home if I scrap all my big 2.4L four plans.
I can't decide: Big screaming four or 2.4lsix or wait to save up some more money and install a 3.2! What do you think I should do?? Geoff Attached image(s) |
ClayPerrine |
Feb 26 2005, 08:40 PM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Go for the six....
But make sure that you don't get DWD while doing it. Or you could end up like me.... I bought a 911 tach at a swap meet (Honey, some day I want to put a six in my car, but not now). That started the 4 years and counting oddysey of my car.... Oh, DougC has a 914/6 flywheel for sale in the parts forum. |
xsboost90 |
Feb 26 2005, 08:42 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
a six would -in theory- just add to the value of your car.
Jeroen |
Feb 26 2005, 08:44 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
go six!
TimT |
Feb 26 2005, 08:48 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
You can break down that 2.4 and rebuild it into a screamer....
get a 20/21 cam or a 158R or GE60 cam, have the heads freshened.....bolt it all together with the Webers that I see on your engine and things will be good. |
ArtechnikA |
Feb 26 2005, 09:46 PM
i think it's going to take more than cams to really wake up a 2,4 T ... |
J P Stein |
Feb 26 2005, 09:53 PM
Got a type number on that, Geoff?
The shroud color says 'T' , but....? |
ClayPerrine |
Feb 26 2005, 09:54 PM
If the webers are factory, it's a T motor. All of the other 2.4 motors were MFI......
Bleyseng |
Feb 26 2005, 10:29 PM
supposed to have RSR cams in it already
Factory carbs Geoff |
red914 |
Feb 26 2005, 10:37 PM
...i believe in coyotes and time as an abstract... Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 |
find a roller and have both!
c'mon, like you haven't already thought of it (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
anthony |
Feb 26 2005, 10:46 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Go for the big 4. Don't you already have the Nickies for that? The conversion parts alone will cost $4K to put that 2.4 in your car.
redshift |
Feb 26 2005, 10:52 PM
I'd put the 2.4/6 in there... but not that one. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
The 2.4 E or S makes my favorite 914 setup. M |
VegasRacer |
Feb 26 2005, 10:53 PM
ELVIRA Group: Benefactors Posts: 8,522 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
six
Attached image(s) |
Brando |
Feb 26 2005, 10:57 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
if the 6 is going to be opened up... best to put some 964 cams in there, straight headers, punch it out a bit, updated cam chain tensioners (oil fed), shuffle-pinned... You can take it up to 2,9 safely. It'll be a screamer. (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
boxstr |
Feb 26 2005, 11:21 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Geoff put that six in your westy. And then get a V8 and go real fast in your 914.
CCLINRH |
J P Stein |
Feb 27 2005, 01:06 AM
The type # is just below the hose clamp in your pic on the right side of the engine....stamped into the case just inboard of the chain housing ....should be 911/XX. Get that number before you do anything.
73.5 2.4T had CIS. Euro 2.4Ts had carbs. |
Trekkor |
Feb 27 2005, 01:22 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
If you want to upgrade to a 3.2 someday, the parts aren't getting any cheaper. You can get all the conversion parts for under $3k if you are me. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Go SIX, please. Thank you. KT |
MecGen |
Feb 27 2005, 06:41 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi
I, like most teeners, have thought about conversions... Put aside HPvs$$ (V8 wins hands down), why does an aircooled six always makes me stop breathing ? If you go for the big four, you will always see that six in the corner of your eye, if you go for the six, you will forget about the four, except when your pulling $$$ out of your pocket. I absolutly did not help, I am confused. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) Cheers Joe (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
scotty b |
Feb 27 2005, 08:30 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
My .02 Put the six in your driver with 67S cams, open the jets, early 911 stock exhaust,if the pistons need replacement go with a set of J.E. high comps., that makes a very fun "cheap" driver. Keep the 4 banger and build a racer!! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
redshift |
Feb 27 2005, 08:43 AM
Uhh... that is an upside down 9.
M |
Lo-Fi Version | Time is now: 1st June 2024 - 04:36 AM |
