Putting old brake pads back in, next question: What are these calipers? |
john77 |
Aug 12 2015, 04:44 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I took my driver side rear brake pads out to check if the rotor was warped. If I want to drive the car 'as is' until I have a chance to get them machined, do I need to adjust the pistons for clearance when I put the old pads back in?
Excuse my ignorance on this, it's all completely new to me. |
BeatNavy |
Aug 12 2015, 05:34 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I think it's a always a good idea, or maybe even just plain necessary, to check brake venting clearance after working on the rear brakes. It's not that hard. Here's a good reference:
http://www.914world.com/bbs2/index.php?showtopic=90625 |
john77 |
Aug 12 2015, 06:57 PM
I think it's a always a good idea, or maybe even just plain necessary, to check brake venting clearance after working on the rear brakes. It's not that hard. Here's a good reference: http://www.914world.com/bbs2/index.php?showtopic=90625 Thanks Rob. |
john77 |
Aug 12 2015, 07:21 PM
Okay, now I'm confused, these aren't the same brake calipers as in Eric's article. There's a raised logo that kind of looks similar and P67 stamped on them. Anyone know what they're off?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439428896.1.jpg) |
914Sixer |
Aug 12 2015, 07:32 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bolt pattern please. 3" or 3.5" ?
john77 |
Aug 12 2015, 07:42 PM
Eric_Shea |
Aug 12 2015, 07:55 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Those are 911 rear M-Calipers with 10mm spacers and vented rotors. You probably no longer have a handbrake.
john77 |
Aug 12 2015, 08:12 PM
Those are 911 rear M-Calipers with 10mm spacers and vented rotors. You probably no longer have a handbrake. Thanks Eric. Nope, no handbrake. Just pulled my copy of 101 Projects off the shelf to see if that could help and noticed they're exactly the same as the ones in the project... So the pistons don't need to be messed with to give the pads clearance on these? I checked on my passenger side rear and the pads are flat against the rotor with no clearance at all. |
Lo-Fi Version | Time is now: 5th June 2024 - 10:07 AM |
