oil bath air cleaner? |
enf2232 |
Oct 19 2015, 06:16 PM
Member Group: Members Posts: 86 Joined: 13-July 14 From: Toledo, OH Member No.: 17,621 Region Association: None |
Looking at what would be my first 914 (72, 1.7, fi). Seller described air cleaner as an oil-bath. Is that original or an aftermarket item? I thought those went out in the '50's.
914Sixer |
Oct 19 2015, 06:23 PM
914 Guru Group: Members Posts: 8,901 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Standard on 1.7 for 70,71,72. Lots of early car owners switched them out and went with the 73 set up with the air filter.
r_towle |
Oct 19 2015, 06:48 PM
Custom Member Group: Members Posts: 24,586 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
era vulgaris |
Oct 19 2015, 07:27 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Sounds like you're not very familiar with VW engines (IMG:style_emoticons/default/wink.gif)
I'd recommend doing ALOT more research on everything about these cars before you make the plunge. Especially if you're not familiar with air-cooled engines. |
ClayPerrine |
Oct 19 2015, 08:53 PM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you want an air cleaner for a 1.7 that uses a paper element, you can have the one I have for the cost to send it to you.
stinkindiesel |
Oct 20 2015, 02:34 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
If you want an air cleaner for a 1.7 that uses a paper element, you can have the one I have for the cost to send it to you. Of course, then all you'll need is a paper filter that will fit (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:36 AM |
