Brakes Fluid, Recommendations |
solex |
Mar 12 2005, 10:31 AM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hello All
I have a stock 75' with a stock braking system. The brakes feel positive but simple do not stop the car as I would expect (I am told the stock system is quite good). It feel worse then a beetle so I suspect that there is something wrong. I plan on digging into the system but would first like to change the fluid but need recommendations, DOT3 or 4 or any others? Thanks, Dan |
solex |
Mar 12 2005, 10:36 AM
I just read the post re: "Took a long drive today" and Bryan recommended DOT 4.
Thanks, Dan |
type47 |
Mar 12 2005, 10:46 AM
my car does not brake as well as i think it should also. so, i'm going to rebuild the calipers. rebuild kits are cheap, about $12/caliper and it's easy. to check for sticking pistons, you have to remove the caliper anyway so while i'm in there...... (famous last words)
brake fluid i've heard recommended is ATE blue and gold. alternate colors so you can tell when the new fluid is coming thru when you do a brake flush |
TimT |
Mar 12 2005, 12:35 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
I use Valvoline Synpower brake fluid in my track car, it is a synthetic DOT 3/4 fluid, and has impressive specs, dry boiling point 502F, wet boiling point 343F
I used to use ATe Blue/gold, but the Valvoline is less expensive |
IronHillRestorations |
Mar 12 2005, 12:46 PM
I. I. R. C. Group: Members Posts: 6,727 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The ATE stuff is good. The only reason there's gold and blue is so you can alternate colors, and know when new fluid is pused through the system.
I've been using Castrol LMA. It's got the same specs as the ATE, and I can get it locally. It doesn't come in colors though. The service interval for brake fluid is two years, regardless of mileage. |
Lo-Fi Version | Time is now: 5th June 2024 - 11:16 AM |
