What's the best lift for an 8' ceiling garage?, and can i fit one 914 under the other?? |
DRPHIL914 |
Dec 7 2015, 08:32 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
or even a boxster or an 996?
looking at a move soon and starting to make some plans on how to set up the new garage., so looking for advice: Garage is 30' x 26', more info to come!!! |
budk |
Dec 7 2015, 08:47 AM
Yes! It's a Bumblebee! Group: Members Posts: 678 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
or eve a boxster or an 996? looking at a move soon and starting to make some plans on how to set up the new garage., so looking for advice: Garage is 30' x 26', more info to come!!! 8" is pretty small.... (IMG:style_emoticons/default/laugh.gif) Have you seen this thread ? lift |
Amphicar770 |
Dec 7 2015, 09:41 AM
Senior Member Group: Members Posts: 1,197 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
The other challenge you will have is that if your ceiling height is 8' and you have standard garage doors, the doors when open are lower than 8'.
Sounds like a small mid-rise lift might be your best bet, although you can not park underneath those. |
GregAmy |
Dec 7 2015, 09:42 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
8" is pretty small.... (IMG:style_emoticons/default/laugh.gif) Yeah, you run the risk of being crushed by a dwarf... |
DRPHIL914 |
Dec 7 2015, 01:22 PM
o.k, so I corrected the 8" vs 8' misprint.
i'll look at that thread, as suggested, thanks. |
jor |
Dec 7 2015, 01:28 PM
Just happy to be here. Group: Members Posts: 183 Joined: 28-July 14 From: LA Member No.: 17,693 Region Association: Southern California |
8" is pretty small.... (IMG:style_emoticons/default/laugh.gif) Yeah, you run the risk of being crushed by a dwarf... I'm glad someone else thought immediately of "This Is Spinal Tap." |
Elliot Cannon |
Dec 7 2015, 04:05 PM
I wish my ceiling was that high. (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) |
DRPHIL914 |
Dec 8 2015, 08:11 AM
went back to the hopefully soon-to-be-mine garage space yesterday, while the wife and kids were deciding who gets what room and where the furniture will go, ive already decided that I will be in the bottom level. The garage is actually 30'x30' !! ceiling is just a bit more than 8'. I didn't put a measuring tape to it but as ii stand flat footed, I can touch an 8' ceiling, so its just a few inches more. and lay out is nice, with 2 8' doors and 4 ft in between them, and 5ft on each side, that give LOTS of space for shelved and storage and can still get in and out of the car!! especially since I have a big boat of a car, a 65 ford that will be in there as well. and since there is a separate work shop and golf cart garage area, none of my wood working tools , lawn mower etc will have to be in the car area!!. BUT after looking up the official dimensions, it appears a 914 is exactly 48" tall stock height, so if I keep both 914's I might have to go low profile tires to get one under the other. , I have not heard of anyone else yet that has done this in an 8' garage. - otherwise since we might not get a golf cart, I may put one of the teeners in that space- it will be tight getting thru the door but will fit fine once inside! so maybe with air let out of car on ground, it will fit? - but the lift could be further forward and the lights and garage door opener will not be a factor. - pictures to come. |
mskala |
Dec 8 2015, 09:33 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
With barely 8', you will have issues to deal with.
With the 4-post style, you will need to raise the car at least 3 inches higher than minimum before the cam lock will be cleared. You will probably need to weld one of the stops at exactly your correct height. Also, you will lose 4 inches due to the platform itself. More crazy ideas: 1) take out ceiling in just the area of the roof, if you can park perpendicular to joists. You can gain 6" and park with the roof removed. My roof has more than normal joist spacing; depending on dimensions you might need to remove one (please brace as appropriate). 2) You seem to have a lot of area to work with, maybe just get a few sets of wheel rollers and just push the cars around. 3) Roll the 914's onto the passenger doors and store vertically (IMG:style_emoticons/default/biggrin.gif) |
tdgray |
Dec 8 2015, 02:42 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
My solution... but it does not sound like you have enough room on the side... and I have one large door not two small ones.
Attached thumbnail(s) |
mepstein |
Dec 8 2015, 02:49 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I like my snap on mid rise lift. I can drive over it in the 914 without any accessory ramps and then it's invisible. It took no prep, just plug it in and step on the button.
74ravenna |
Dec 8 2015, 03:27 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
mepstein |
Dec 8 2015, 03:45 PM
I like my snap on mid rise lift. I can drive over it in the 914 without any accessory ramps and then it's invisible. It took no prep, just plug it in and step on the button. Is your Snap-on an electric lift? It uses a power pack. Plugs into the wall and the hose attaches to the lift. |
wndsnd |
Dec 8 2015, 05:26 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Will a mid rise scissor lift allow enough clearance to complete a six conversion on the chassis?
Motor mounts, running oil lines to a front cooler, etc? Certainly better than working under stands. |
r_towle |
Dec 8 2015, 05:28 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yes, but you might want to lift it, set the wheels on block, lower the lift and add the high lift truck adapters. Those posts can be 6-8 inches tall and will provide loads of clearance between the lift arms and the chassis.
Figure you have to do that once. |
tdgray |
Dec 8 2015, 05:40 PM
Mine has a power pack as well...Atlas 6000.
If you can see it...I have the truck adapters as well...the space under the MGC. I changed the boys exhaust on his mini and e brake cables...plenty of room. Plus it's portable. ..big plus in my always in flux garage. |
wndsnd |
Dec 8 2015, 06:50 PM
The adapters are only 6"?
r_towle |
Dec 8 2015, 06:51 PM
Can be pretty tall, call Greg smith lifts in New Hampshire, no sales tax and it would fit on my trailer (IMG:style_emoticons/default/smile.gif)
wndsnd |
Dec 8 2015, 07:07 PM
Might take you up on that. All cash going into engine right now.
Will not touch car untill engine is complete. Will drive it until the snow flies. |
Steve |
Dec 8 2015, 07:34 PM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I have a Bendpak MD6xp
http://www.bendpak.com/car-lifts/specialty-lifts/md-6xp.aspx No problem with my 8' garage. I can get to everything except for the floor pan. I had no problems pulling my 3.2 six motor and trans, hell hole repair and re-installation of everything. I have a trashed hydraulic stool on the lowest setting that I roll around on. I am 5'10" and have no problems rolling around under the car to work on it. Night and day better than jack stands and cardboard to lay on. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:05 PM |
