FS Front and rear Targa Latches, $60 per pair front or rear shipped |
bdstone914 |
May 21 2016, 08:16 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Pictures to follow.
I have a few more pairs of rear targa latches that have new springs and clips and are powder coated. One pair gloss black and others in satin black. $60 a pair shipped. Note that there are two variations of rear latches. The difference is the height and distance between the bumps. The distance between the bumps matches to the rubber block on the top. Not sure of the year break but my 73 VIN 4732915786 has the tall bumps. I suspect that the latches go with the two different tops, early and late. PET shows the tops change in 1973 at VIN 4732926221. They show the same part number for latches for all years. They show two part numbers for the block but the application change is not clear as the 914 563 033 10 is for 974-6/4 and the 914 563 033 19 for 914-1.7/1.8V. Using the wider bump ones on the wrong top allows movement of the top. The other wrong combo does not allow the block to sit flush to the latch. Best to check what is on your car. I have one pair of front latches at this time for $60 a pair shipped. This pair were spray can painted with caliper paint. I have several more pairs that are getting sand blasted and we are going to try to powder coat them. Have to see if the powder coating can be thin enough to not make the moving parts rub. I know we can powder coat the hook parts. One part is zinc and we have had some gassing problem ( not flatulence ) with the zinc causing bubbles in the paint. If it is a problem the latches will be wet painted. Bruce |
Jett |
May 21 2016, 08:36 PM
Senior Member Group: Members Posts: 1,641 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Bruce I need a set of rear latches for my 73. Is that possible?
Thanks |
bdstone914 |
May 21 2016, 09:01 PM
Jett |
May 21 2016, 09:21 PM
Sure, will send dimensions in the am
Jett |
May 22 2016, 11:27 PM
The rubber bottom is approximately 1"
Harpo |
May 23 2016, 05:57 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Hey Bruce,
I need a pair of rears. The mating part on my top is 32mm at the widest point. Thanks David |
bdstone914 |
May 23 2016, 06:07 PM
Hey Bruce, I need a pair of rears. The mating part on my top is 32mm at the widest point. Thanks David Hi David, I know you have a Frankenstein car but I think the body is a 75 or 76 which would mean you need the big bump rear latches. Paypal to bdstone914@aol.com Thanks |
Jett |
May 23 2016, 08:39 PM
Hello Bruce, the rubber was approximately 1" at the smallest point. If that works, I'd also like a set of the front latches please.
scrz914 |
May 23 2016, 09:26 PM
Member Group: Members Posts: 398 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
Hi Bruce, have you ever contemplated plasticoat on the rear latches like OE (with pc)? I believe the handles and the hook were the parts covered. Do you know a modern product durable enough that might stand the test of time?
bdstone914 |
May 23 2016, 10:13 PM
Hi Bruce, have you ever contemplated plasticoat on the rear latches like OE (with pc)? I believe the handles and the hook were the parts covered. Do you know a modern product durable enough that might stand the test of time? I tried it and it did not look do good. Hard to do the handle and not the housing. The original plastic coating did not hold up and wore through on the hooks allowing moisture in and rust to form. Bottom line, more work and cost for a less durable finish. |
jkb944t |
Sep 2 2016, 05:46 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Bruce,
I have a 1973 914 with the rear latches shown below. Is the picture sufficient or do I need to measure them? If the picture is enough do you have a set of these in stock? Jeff B |
bdstone914 |
Sep 2 2016, 07:00 AM
Bruce, I have a 1973 914 with the rear latches shown below. Is the picture sufficient or do I need to measure them? If the picture is enough do you have a set of these in stock? Jeff B You have the late style with the taller hump. I have a pair in stock. Paypal addy is bdstone914@aol.com |
Lo-Fi Version | Time is now: 11th June 2024 - 04:37 AM |
