WTB: Tach Glass, Want to Convert from Plastic |
914Sixer |
Jul 22 2016, 06:22 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Need the glass from an non working tach. No chips or pits.
TheCabinetmaker |
Jul 22 2016, 06:24 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I have some Mark. Glass or plastic?
malcolm2 |
Jul 22 2016, 06:53 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Timothy_ND28 uses fresh glass when he adds the LED, maybe he can help with a brand new piece.
eric914 |
Jul 22 2016, 09:02 AM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
When i redid my gauges i went to a custome frame shop and had them cut a piece of non glare glass for me. They were only a few $ each.
TheCabinetmaker |
Jul 22 2016, 10:38 AM
bdstone914 |
Jul 22 2016, 08:38 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
We have them new at Pelican for all three sixes of 911 and 914 gauges. They come from North Hollywood Speedo.
timothy_nd28 |
Jul 22 2016, 09:09 PM
Weird, I actually spent the last two weekends at my uncles machine shop using his waterjet. I've been cutting lenses for our gauges and the 911 speedo with the hole for the odometer reset.
pete000 |
Jul 23 2016, 11:30 AM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Could someone post a how to remove thE bezel on the gauge without messing up the bezel. I tried once and failed big time.
dangrouche |
Jul 25 2016, 09:28 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
http://www.914world.com/bbs2/lofiversion/i...hp?t216289.html
here is a write-up; I started with a small flat blade screwdriver, to get a bit of the aluminum to open up, then I slowly pry go around with a (HF) scratch awl, (careful not to puncture the front of the bezel), then transition to a larger scratch awl, and go around and around and around eventually raising up the lip. you don't pry it open all at once, you go around several times, progressing more and more as you go around the entire circumference |
Tjmrfe |
Jul 25 2016, 03:51 PM
NON IMPEDING RATIONE COGITATIONIS Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
Could someone post a how to remove thE bezel on the gauge without messing up the bezel. I tried once and failed big time. I just did mine, put those cool white face gauge faces on....craftsman sells a good "wiring" screwdriver, you take it, perpendicular to the body & peel the rim up, once I had a good bit up, I worked the edge like an old fashion can opener, pivoting the screwdriver using the speedo body as leverage. I went once all the way around. And then gently pry at a few opposing spots to "pop" over the edge of the speedo rim....it is not for the UN-patient...I messed my 1st trim up a little, but the rubber edge hid most of my mistakes, and the rest (and I did the small center ones as well) came out great, got the white faces on, and with the new LED bulbs, it's like super cool....good luck. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:09 AM |
