Conversion Oil Tank Filter Console, Oil Filter does not fit |
mmascari |
Jul 30 2016, 02:45 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I installed a PMS oil tank and oil filter console today and discovered that the oil filter will not fit. It hits the air blower bracket and won't screw on to the console. What do you guys do to solve this? Cut out the bracket (I'd rather not do that) or do thay make a smaller profile oil filter? Let me know what others have done to solve this. Thanks!
Attached thumbnail(s) |
rgalla9146 |
Jul 30 2016, 03:03 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
a 6 doesn't have (or need) a blower motor.
off with the mount ! how would you make a smaller oil filter ? |
mepstein |
Jul 30 2016, 03:15 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
a 6 doesn't have (or need) a blower motor. off with the mount ! how would you make a smaller oil filter ? (IMG:style_emoticons/default/agree.gif) chop off the bracket. |
mmascari |
Jul 30 2016, 04:44 PM
Figured as much.....thanks guys!
Mark Henry |
Jul 30 2016, 06:15 PM
Are you using the relay board? If not cut the brackets off.
What year is your 914 and are you using carbs/rainhats? Cars with the charcoal filter in the engine compartment you have to cut off the stud that it bolts to. Do you still have the /4 engine bar mounts? you can cut them off as well... (IMG:style_emoticons/default/sawzall-smiley.gif) |
Steve |
Jul 30 2016, 07:09 PM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Are you using the relay board? If not cut the brackets off. What year is your 914 and are you using carbs/rainhats? Cars with the charcoal filter in the engine compartment you have to cut off the stud that it bolts to. Do you still have the /4 engine bar mounts? you can cut them off as well... (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/agree.gif) I cut off and tossed everything. Don't need any of it. |
mmascari |
Jul 30 2016, 07:29 PM
My car is a '73 and the engine is a 3.0sc motor. I am planning on using carbs on the engine, so will I even need the relay board? Or is it really just for fuel injection for the 4?
mepstein |
Jul 30 2016, 07:49 PM
My car is a '73 and the engine is a 3.0sc motor. I am planning on using carbs on the engine, so will I even need the relay board? Or is it really just for fuel injection for the 4? You don't need it. Original 6's had them. You can decide how you want to wire up your engine and either use one or delete it. |
mmascari |
Jul 30 2016, 08:48 PM
[/quote] You don't need it. Original 6's had them. You can decide how you want to wire up your engine and either use one or delete it. [/quote] I guess I have a lot to learn. |
Mark Henry |
Jul 30 2016, 10:05 PM
My car is a '73 and the engine is a 3.0sc motor. I am planning on using carbs on the engine, so will I even need the relay board? Or is it really just for fuel injection for the 4? Perry Kiehl makes a conversion harness that deletes the relay board. Makes the engine harness plug and play. http://www.914world.com/bbs2/index.php?showtopic=24228 |
PanelBilly |
Jul 30 2016, 10:15 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Both the board and the fan motor mount will just get in the way.
Lo-Fi Version | Time is now: 8th June 2024 - 03:18 AM |
