87m491 |
Member ![]() ![]() Group: Members Posts: 330 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States ![]() ![]() |
Does anyone have a preferred "shortcut" for removing the retaining "U" tab on the soft line mounts to the body? The bottom ones behind the wheels are a snap as there is plenty of remove to lever with a screwdriver or other, but the upper side which is up at the edge of the engine bay has very little maneuvering room to get a tool in, on , around.
thx Mike |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
IIRC I use a small pair of vise-grips and clamped onto the raised portion of the tab.
Then I used a screwdriver tho pry the visegrip head away from the brake line fitting. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,786 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
You're replacing the hoses ?
Cut the hose off the metal fitting then use a 17mm deep socket (or is it 14mm?) with a 12" extension to turn the fitting off the 11mm nut on the brake tube. Better yet, use a "crow foot" type tubing wrench and "lean" it against the nearby wall as you turn the bigger fitting off with the ratchet and socket. Use a vise grip and a flat screwdriver to remove the spring clip first |
87m491 |
You've described how I finally got the upper hose separated perfectly. Took me a while to figure since I was replacing them, I could cut off the hose near the fitting and use a deep socket 17 instead of 1/8 turn at a time with the crows foot!.
That said, removing the retaining clip is a PITA. I thought small vise grip but precious little room, at least on the drivers side where I started and am currently stuck, but will try again as you and the previous poster mentioned. You're replacing the hoses ? Cut the hose off the metal fitting then use a 17mm deep socket (or is it 14mm?) with a 12" extension to turn the fitting off the 11mm nut on the brake tube. Better yet, use a "crow foot" type tubing wrench and "lean" it against the nearby wall as you turn the bigger fitting off with the ratchet and socket. Use a vise grip and a flat screwdriver to remove the spring clip first |
kid914 |
ALWAYS lead...NEVER follow!!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,535 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada ![]() |
Is replacing the brake lines worth it to go with the braided lines??? (IMG:style_emoticons/default/confused24.gif)
87m491 |
I went with braided only because I could find DOT units and a set of 4 was ~$100. That said even though they were for "Porsche".. the fitting was 11/16ths and not 17mm. I couldn't figure how to get a grip on the clip with vice grips etc. but finally got the retaining clip off by working through the engine compartment and levering with a long screwdriver through the rain drain holes! Hopefully the other side tomorrow!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1474237489.1.jpg) Is replacing the brake lines worth it to go with the braided lines??? (IMG:style_emoticons/default/confused24.gif) |
rgalla9146 |
You've described how I finally got the upper hose separated perfectly. Took me a while to figure since I was replacing them, I could cut off the hose near the fitting and use a deep socket 17 instead of 1/8 turn at a time with the crows foot!. That said, removing the retaining clip is a PITA. I thought small vise grip but precious little room, at least on the drivers side where I started and am currently stuck, but will try again as you and the previous poster mentioned. You're replacing the hoses ? Cut the hose off the metal fitting then use a 17mm deep socket (or is it 14mm?) with a 12" extension to turn the fitting off the 11mm nut on the brake tube. Better yet, use a "crow foot" type tubing wrench and "lean" it against the nearby wall as you turn the bigger fitting off with the ratchet and socket. Use a vise grip and a flat screwdriver to remove the spring clip first Try using a vise grip as shown in the photo. Rotate it and pull at the same time, not too forceful. Use some WD40 and as soon as you can see a small opening in the clip use a flat screwdriver to lever the clip off. Attached thumbnail(s) ![]() |
kid914 |
I went with braided only because I could find DOT units and a set of 4 was ~$100. That said even though they were for "Porsche".. the fitting was 11/16ths and not 17mm. I couldn't figure how to get a grip on the clip with vice grips etc. but finally got the retaining clip off by working through the engine compartment and levering with a long screwdriver through the rain drain holes! Hopefully the other side tomorrow! (IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1474237489.1.jpg) Where did you source them from?? Is replacing the brake lines worth it to go with the braided lines??? (IMG:style_emoticons/default/confused24.gif) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,993 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Is replacing the brake lines worth it to go with the braided lines??? (IMG:style_emoticons/default/confused24.gif) No |
87m491 |
Checked my records and sourced from Pelican, though made by "Troutman". $68. The lines look robust but they are not very flexible and install was a little tougher than would be with more flexible rubber lines.
[quote name='kid914' date='Sep 18 2016, 04:40 PM' post='2400142'] [quote name='87m491' post='2400091' date='Sep 18 2016, 06:24 PM'] I went with braided only because I could find DOT units and a set of 4 was ~$100. That said even though they were for "Porsche".. the fitting was 11/16ths and not 17mm. I couldn't figure how to get a grip on the clip with vice grips etc. but finally got the retaining clip off by working through the engine compartment and levering with a long screwdriver through the rain drain holes! Hopefully the other side tomorrow! Where did you source them from?? |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Believe it or not....I.d rank this as one of the biggest PITA.s on the 914.
Great information and great solution. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I just use a pair of side cutting pliers, aka, diagonal cutting pliers, or just plain dikes. Much easier than screwing up the hole for the drain hose.
87m491 |
Doing the other side, I hit on the "best" way so far. It is pretty easy, even in the tight confines to cock the retainer left or right so that the unreachable side sticks out from behind the mounting flange.....
(IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1474827617.1.jpg) once you accomplish this, you can "walk" the retainer out using a flat screwdriver on each side as the retainer peeks out side to side. Out in 15 seconds. Time to find it after it flew out about 1 minute! (IMG:http://www.914world.com/bbs2/uploads_offsite/i723.photobucket.com-14731-1474827618.2.jpg) Believe it or not....I.d rank this as one of the biggest PITA.s on the 914. Great information and great solution. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,187 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
You've described how I finally got the upper hose separated perfectly. Took me a while to figure since I was replacing them, I could cut off the hose near the fitting and use a deep socket 17 instead of 1/8 turn at a time with the crows foot!. That said, removing the retaining clip is a PITA. I thought small vise grip but precious little room, at least on the drivers side where I started and am currently stuck, but will try again as you and the previous poster mentioned. You're replacing the hoses ? Cut the hose off the metal fitting then use a 17mm deep socket (or is it 14mm?) with a 12" extension to turn the fitting off the 11mm nut on the brake tube. Better yet, use a "crow foot" type tubing wrench and "lean" it against the nearby wall as you turn the bigger fitting off with the ratchet and socket. Use a vise grip and a flat screwdriver to remove the spring clip first I just completed this hose replacement, the '75 model year was a very good example without crud/rusting/etc. The "C" clip was the hardest part of the job and I was not bale to grab it across as shown, but was able to grab it by the 1/8" or so and wiggle it loose. If working on a crusty example I would suggest to saturate the clip upper side a day or so ahead of time Try using a vise grip as shown in the photo. Rotate it and pull at the same time, not too forceful. Use some WD40 and as soon as you can see a small opening in the clip use a flat screwdriver to lever the clip off. |
Lo-Fi Version | Time is now: 31st July 2025 - 03:48 PM |
