Rebuilt Alternator, Here We Go Again |
914Sixer |
Oct 29 2016, 05:45 AM
914 Guru Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I bought a rebuilt AC Delco rebuilt alternator because it was all I could find a couple of months ago. I checked it when it came and everything seemed to be correct. Well yesterday, I pulled it out to transfer the cover. Got the cover pulled off the old one and went to test fit to the AC Delco before painting. The posts of the newly rebuilt one were over 1/2 " too long. The next thing I saw was the diode plate was sticking up OVER the top of the housing. (IMG:style_emoticons/default/headbang.gif) The only thing to do was start disassembly of the back of the alternator. Lifted up diode plate and took off the too tall nuts holding the post and replaced them with thinner nuts. This let the diode plate drop below the housing. One problem solved and on to the wrong size bolts. I measured the length of the the ones from the old alternator and got out the cut off wheel and went to work. With the bolts cut off I was able to test fit every thing. What ever happened to plug and play???? (IMG:style_emoticons/default/confused24.gif)
Attached image(s) |
87m491 |
Oct 29 2016, 10:32 AM
Member Group: Members Posts: 276 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
I hear you on "all you could find", BTDT. But going with a Delco rebuild for a Porsche and thinking Plug N Play was more Hopium than a real expectation. I'm guessing that is at least half the reason so many folks go with a local rebuilder or do it themselves. I have had good luck with aspwholesale.com. for Bosch alt/starter parts. Also feel you on the delay getting parts bolted up. Often mine sit well past the return period before I get to them and find they are incompatible. Next new years resolution is install parts as they hit my in box!
I bought a rebuilt AC Delco rebuilt alternator because it was all I could find a couple of months ago. . What ever happened to plug and play???? (IMG:style_emoticons/default/confused24.gif) |
Downunderman |
Oct 29 2016, 12:38 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
So which AC Delco fits?
jim_hoyland |
Oct 29 2016, 02:45 PM
Get that VIN ? Group: Members Posts: 9,328 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have a spare that had been rebuilt at a local shop; forgot whether it was originally on my car or I picked it up at the swap meet: from the pictures, does the back appear that it will fit ?
And; is my unit missing the black part (?) in the middle ? Don't know what it is yet Attached image(s) |
ClayPerrine |
Oct 29 2016, 04:12 PM
Life's been good to me so far..... Group: Admin Posts: 15,543 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Every single rebuilt alternator I have purchased for a /4 in the last 30 years had this issue. The reman shop doesn't give a shit about the length of the stud.
And for 30 years I have been cutting off the studs to clear the cover on the back. Oh.. and don't forget the rubber boot over the positive terminal. |
914Sixer |
Oct 29 2016, 08:16 PM
Jim,
Your alternator looks to be correct. Clay is also right, DO NOT forget the rubber boot that goes on the red wire. It is a VW boot used on Bugs. |
bdstone914 |
Oct 29 2016, 08:19 PM
bdstone914 Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have a local shop that rebuilds them correctly. He has been doing it for 25 years. I have a bunch of cores and can get one rebuilt for $85 plus a core charge of $25.
Dont trust comericial rebuilds. |
jim_hoyland |
Oct 29 2016, 09:13 PM
Jim, Your alternator looks to be correct. Clay is also right, DO NOT forget the rubber boot that goes on the red wire. It is a VW boot used on Bugs. Is that black thingy in the middle missing from mine ? And, is this boot suitable ? Attached thumbnail(s) |
mepstein |
Oct 29 2016, 09:31 PM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a local shop that rebuilds them correctly. He has been doing it for 25 years. I have a bunch of cores and can get one rebuilt for $85 plus a core charge of $25. Dont trust comericial rebuilds. (IMG:style_emoticons/default/agree.gif) I do the same. They rebuild them on my core. I know what I'm getting back is correct. |
ClayPerrine |
Nov 1 2016, 12:29 PM
Anyone want to try this?
Bosch 95 amp industrial alternator. From the pictures, it looks like a 914 alternator. |
914Sixer |
Nov 2 2016, 06:14 PM
Might work, but I think the front plate would need to be fitted with a 914 one.
Lo-Fi Version | Time is now: 17th June 2024 - 01:09 PM |
