MicroSquirt monitoring, Monitoring a dual carbed type IV |
moto914 |
Feb 28 2017, 10:06 AM
Newbie Group: Members Posts: 43 Joined: 27-February 17 From: Greenville SC Member No.: 20,878 Region Association: South East States |
Hi guys. I'm a new member so first of all: Thank you to all the garage and paddock people, you all are great inspirations.
My thought was that if I had any plans of upgrading the HP of the type IV, monitoring cylinder temp, intake manifold pressure and more would be inevitable. Another thought was that I may be able to use two map sensors and get an idea how carbs balanced left vs right. The MicroSquirt controller and some sensors are now hooked up, and working. With a android tablet mounted, I can see or save the outputs. Here are some screen shots. MSDroid app --------------------------- RealDash app --------------------------- Shadow Dash app I plan on gradually progressing from monitoring to controlling. Hope this helps someone doing the same. This post has been edited by moto914: Jul 30 2021, 11:01 AM |
Bills914-4 |
Feb 28 2017, 11:11 AM
Member Group: Members Posts: 310 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Welcome to the World (IMG:style_emoticons/default/biggrin.gif) ,
jmill |
Feb 28 2017, 11:15 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
moto914 |
Feb 28 2017, 11:26 AM
Checking out your thread, and thanks. |
Mark Henry |
Feb 28 2017, 11:52 AM
Another thought was that I may be able to use two map sensors and get an idea how carbs balanced left vs right. I doubt if that will work well. The map signal is so crappy with dual carbs/ITBs I bet you will be casing your tail to infinity and beyond. Might work a bit with a stock cam, but definitely not with any performance cam. My vac is so crap on my engine, a 2600cc, performance cam, with 46mm ITB's, that I gave up tring to tune it on MAP and now run TPS only. Pretty well solved every issue I was having, car runs almost like stock now, perfect AFR. |
moto914 |
Feb 28 2017, 12:25 PM
Another thought was that I may be able to use two map sensors and get an idea how carbs balanced left vs right. I doubt if that will work well. The map signal is so crappy with dual carbs/ITBs I bet you will be casing your tail to infinity and beyond. Might work a bit with a stock cam, but definitely not with any performance cam. My vac is so crap on my engine, a 2600cc, performance cam, with 46mm ITB's, that I gave up tring to tune it on MAP and now run TPS only. Pretty well solved every issue I was having, car runs almost like stock now, perfect AFR. Yes. I noticed the map signal jumping around. I'm just using the average while making and comparing adjustments at idle. Thanks for the info! The TPS tip may be the way to go in my future. |
Mark Henry |
Feb 28 2017, 12:37 PM
I'm guessing you're thinking of going turbo in the future, because of your screenshot?
You likely would have a better MAP signal because you would be running a single TB. |
moto914 |
Feb 28 2017, 12:52 PM
I'm guessing you're thinking of going turbo in the future, because of your screenshot? You likely would have a better MAP signal because you would be running a single TB. Thinking of turbo; but first a rebuild on a spare engine with naturally aspirated carbs, then fuel injection. I'm going for the basics first. |
Chris914n6 |
Feb 28 2017, 03:53 PM
Jackstands are my life. Group: Members Posts: 3,336 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I think you would be better off in the short term using the old fashioned carb balancing tool.
(IMG:http://www.914world.com/bbs2/uploads_offsite/mgaguru.com-431-1488318790.1.jpg) Also happy to see another MS user. (IMG:style_emoticons/default/beer.gif) I'm looking heavy into MS3/x for my VQ35 swap. |
moto914 |
Feb 28 2017, 04:05 PM
I think you would be better off in the short term using the old fashioned carb balancing tool. (IMG:http://www.914world.com/bbs2/uploads_offsite/mgaguru.com-431-1488318790.1.jpg) Also happy to see another MS user. (IMG:style_emoticons/default/beer.gif) I'm looking heavy into MS3/x for my VQ35 swap. Good suggestion.. Always good to have the real world to base on. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:59 PM |
