| mmascari |
Jul 2 2017, 12:48 PM
Member ![]() ![]() Group: Members Posts: 322 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I am relocating my fuel pump on my '73 to the front of the car. I am feeding the wire off the fuse panel but also want to add an inline fuse. Does anyone have an idea of what amperage fuse I should run between the fuse panel and pump? The pump is a Pieburg
| porschetub |
Jul 2 2017, 01:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,157 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I am relocating my fuel pump on my '73 to the front of the car. I am feeding the wire off the fuse panel but also want to add an inline fuse. Does anyone have an idea of what amperage fuse I should run between the fuse panel and pump? The pump is a Pieburg Better to run from the original supply so you retain a relay and original fuse,if you don't you will need a 7.5amp close to the switched supply ,I ran a wire down the tunnel into the engine space and connected to the original supply. |
| Larmo63 |
Jul 2 2017, 03:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I'm running my front Pierburg type pump to a dash switch, then to #8 or 9 fuse. That way, I can turn on my power without the fuel pump running on the whole time.
| mmascari |
Jul 3 2017, 09:30 AM
I'm running my front Pierburg type pump to a dash switch, then to #8 or 9 fuse. That way, I can turn on my power without the fuel pump running on the whole time. So you don't have an additional fuse between the fuse panel and the pump? I am doing a six conversion as well so I am not retaining the relay board. |
| larryM |
Jul 4 2017, 01:21 PM
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California
the 911 3.2 pump is protected by a 25A fuse
maybe worth looking at these threads http://forums.pelicanparts.com/porsche-911...fuse-issue.html http://www.914world.com/bbs2/index.php?showtopic=113517 I'm running my front Pierburg type pump to a dash switch, then to #8 or 9 fuse. That way, I can turn on my power without the fuel pump running on the whole time. So you don't have an additional fuse between the fuse panel and the pump? I am doing a six conversion as well so I am not retaining the relay board. |
Lo-Fi Version | Time is now: 14th August 2026 - 08:45 PM |
