SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,244 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
sooooo, i'm getting my car ready for sundays AX and i'm thinking about changing the oil.
i used to use 10-30 in the past, but that was the oil of choice in germany. CA turns out to be just a tad warmer on avarage as good 'ole germany ... so what's a good weight to run in a semi competition enviroment? what brand will hold up to the unimaginable forces i'm going to put through this little 2056? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Andy |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
20-50 Valvoline synthetic or 20-50 Mobile-1 (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif)
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Id say 20-50, Kendall for regular oil, 15-50 Mobil 1 or 20-50 Valvoline for synthetic schtuff (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
20/50 Castrol dinosaur oil....
MarkV |
bernbomb914 |
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 ![]() ![]() |
Jake said Royal Purple Syn 20-50 was the best on his dyno so that is what I run
Bernie |
tommy914 |
Life is a journey, enjoy every turn. ![]() ![]() ![]() Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None ![]() |
EVOO works good for me!
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
i like 20/50 castrol..,.. now that the rings seem to have seated in mine, i might switch to synthetic... need to fix a leak,though...
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Haynes says:
SAE 10 below 5 degrees SAE 20 between 5 and 32 degrees SAE 30 above freezing Joe Blow says use synthetic. John Doe says don't use synthetic. Jim Bob says use 30 weight. Jim Bob's brother says use heavier... I've been running 10-40 dinosaur squeezings. The best I can tell it fits the bill in most common scenarios. I never know how to get an answer out of these kinds of threads. How can anyone determine the difference between someone's opinion and what really makes a tangible difference? Andy, you called for the oil gurus.... Who are the gurus?? If the Cap'n posts a gospel answer is everyone else a dumb ass? ( (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Hey Krusty... I'm just joking and respect you. ) Calling Mr. Raby... Hey Jake, what say you? Royal Purple Syn 20-50? (Thanks Bernie!) |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,823 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I'd toss my .02 for the 20/50 too. Synthetic if it's good and tight, and regular 'ol dino juice if it's seeping any (why piss out $5 a qt oil?).
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
If you change to 20-50, check your oil temps. I swear that changing from 20-50 to 10-40 makes my car run considerably cooler. That and cooling flaps underneath made a HUGE difference. (30 degrees)
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
I am switching from running Kendall 20-50 as now that the motor is apart with 10k on it, I have seen some varnish build up inside. Switching to Mobil1 after the rings seat.
My oil temps AXing have hit the 230-240 range with Blair and I sharing the car running in the same race group. 8 hard runs in a short time gets the oil hot. Check out this site: http://www.bobistheoilguy.com/ |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,285 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
I'm no guru, but I like Valvoline synthetic... but if the motor's leaking, it's not worth the $5/qt
cdmcse |
Member ![]() ![]() Group: Members Posts: 340 Joined: 17-December 04 From: Georgetown, Ky Member No.: 3,305 ![]() |
This is my own personal experience, but I used to have an MGB that had a performance engine. It was very high compression (11:1 IIRC) and all the parts were for performance. This engine turned out to be very demanding on oil. I tried several brands of regular oil: Quaker State, Valvoline, Pennzoil, Shell, Castrol, and probably others.
I drove the car very hard (Hey I was a teenager), but in a normal 3000 mile change interval the car would actually break down most of the oil I tried. This was a basically a brand new engine from top to bottom, but the oil would turn into a thick hard black sludge on the rockers and in the pan (ask me if I had to take it off to clean it (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) ). After switching to several different oils I finally found one that kept the engine sparkly clean between oil changes and didn't suffer thermal breakdown... CASTROL (Seems like valvoline lasted the shortest time). After that I drove the car about 40K miles before I sold it with nary a problem. I never tried any synthetics in the engine, though. Because of this I only use Castrol in every car I own. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,008 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
ok...
I'll throw in one more vote for the 15-50 mobil 1 syn. I've always run it on anything aircooled. (even old motor cylcles) everybody has an old story so here is mine: my 1st ever 914 motor was built by a friend named Daryl Bailey. He has passed on now, but used to build 6-8 motors every year that would be in the formula Vee run offs. anyways I put 60,000 miles on that motor and a lot of those were on the race track. We had a two driver car and way back in the 80's did not even have an oil cooler on it. Alot of times the car would come in from a DE session with the oil temp already into the red zone and then the 2nd driver would get in and go. I credit the mobil 1 for that motor lasting the way it did and have pretty much exclusively used it on the track since. I do think that the air cooled motors demand more from oil (oil cooling). I've had mobil 1 leak from a lot of things that were not rebuilt... but I think your motor has been opened recently.. I wouldn't break it in on mobil 1 but I'd switch to it as soon as you are confident its broken in. brant |
BMartin914 |
||| ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest ![]() |
15/50 Mobil 1
Carrera916 |
Member ![]() ![]() Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 ![]() |
I use Amsoil 20/50 on all of my cars...been very happy with it...
even trans gear oil, antifreeze & ATF are amsoilized into my car! been an Amsoil dealer for about 6-7 years...people raved over them, especially the gearbox oil.... j |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
me??
for my "standard" 914 motor....whatever is on sale for 90 cents or less at Kragens (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
hehehe Ill throw in a curveball
I use Shell Rotella in all my vehicles. |
Lo-Fi Version | Time is now: 3rd July 2025 - 09:28 PM |
