Advice needed -Difficult to get into 1st/reverse, As a result of adding the left side under warm air guide,- |
DRPHIL914 |
Sep 13 2017, 03:44 PM
Dr. Phil Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so figuring that i should put this missing piece on to help cooling of underside heads(this is what ive been told anyway),
i put the piece on and didnt think there would be a problem. car was in neutral when installing it and all went very smoothly all the holes lined up, Very hard to get it into 1st or reverse now- i will qualify this by adding that i have converted the exhause to a early Sshe's with triad- its a 2.0 75 car but all the exhaust etc is backdated so to speak- i may take this off when i get to Helen if it can't be rectified more easily- Thoughts? Anyone else ever run into this? Attached thumbnail(s) |
r_towle |
Sep 13 2017, 04:16 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Firewall bushing, shifter console bushing, or bent rod.
DRPHIL914 |
Sep 13 2017, 05:21 PM
Rich,
i did replace all bushings 2 years ago i should have mentioned that, so it is possible the bar has a bend, - its been shifting fine, perfectly before this- one would have to compare this shift bar with another one to know i guess- its a bit better than when i left home today, but still very tight |
JOEPROPER |
Sep 13 2017, 05:40 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I ran into this when I installed the SSI Heat exchangers on my car a few weeks ago. I just removed it because I figured I wouldn't be needed much longer and I had to drive the car home that day. Not sure how critical it is... but it is there for a reason I guess.
r_towle |
Sep 13 2017, 05:49 PM
See if you can get someone to shift it while you watch from underneath.
It may be simple to put some spacers in to lower it enough so it stops rubbing. |
rhodyguy |
Sep 13 2017, 05:52 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
That's the wrong one. It's For a tailshift. With the SS, the one you need the courve goes Above the rod.
K |
DRPHIL914 |
Sep 13 2017, 05:55 PM
76-914 |
Sep 13 2017, 05:56 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Must be Kevin. It sits very close to the rod.
DRPHIL914 |
Sep 13 2017, 06:04 PM
That's the wrong one. It's For a tailshift. With the SS, the one you need the courve goes Above the rod. K Guess i will have to search for the correct one and sell this one- i got it from Brad and 914ltd brand new powder coated - who wants it?? btw as luck would have it Peter(vysoc) is close ans has offered to let me take my car to his shop down the road from Helen tomorrow- probably just take it off- |
rhodyguy |
Sep 13 2017, 06:05 PM
Check your pms Phil.
ndfrigi |
Sep 13 2017, 07:04 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
DRPHIL914 |
Sep 13 2017, 07:36 PM
bulitt |
Sep 14 2017, 03:44 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
rhodyguy |
Sep 14 2017, 05:27 AM
When trying to engage 1/r, the rod rotates down and bangs into the TS WAG. That can not be remedied unless that WAG is removed. Phil's problem will be resolved in a couple of days.
Lo-Fi Version | Time is now: 16th June 2024 - 02:31 PM |
