Headlight Issue, Wont go down |
mmascari |
Apr 7 2018, 12:53 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I know this topic has been beat to death but I need some guidance on my headlight issue. I think it is unique. Anyway, my headlights pop up and the lights turn on but as soon as I push the knob in to turn them off the headlights do not go down.....I have to manually turn the knob on the motor to get them down. ??
Steve |
Apr 7 2018, 12:57 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Try swapping the relay from side to side.
Wyvern |
Apr 7 2018, 01:00 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
Both of them , or just 1 ?
Have you tried plugging in a different round relay ? You could borrow one from the engine bay block to test it. I will be at the PCA Diablo Region Porsches and Pastries tomorrow in Pleasanton. Come on out and I'll be happy to give it a quick look at . 10am Sugaree Bakery, on Bernal |
mmascari |
Apr 7 2018, 01:01 PM
JFG |
Apr 7 2018, 02:33 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I had this on one headlight. It was a faulty relay.
mmascari |
Apr 7 2018, 02:53 PM
mmascari |
Apr 7 2018, 02:54 PM
Both of them , or just 1 ? Have you tried plugging in a different round relay ? You could borrow one from the engine bay block to test it. I will be at the PCA Diablo Region Porsches and Pastries tomorrow in Pleasanton. Come on out and I'll be happy to give it a quick look at . 10am Sugaree Bakery, on Bernal OK, maybe I will come by. Look for my silver 914. |
jim_hoyland |
Apr 7 2018, 06:47 PM
Get that VIN ? Group: Members Posts: 9,315 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Had a similar issue; turned out a tiny wire became disconnected from a diode. There are pics posted
jim_hoyland |
Apr 7 2018, 06:50 PM
Like this, not easy to see....
jim_hoyland |
Apr 7 2018, 06:51 PM
Like this, not easy to see....the black plastic covers one, the second one is uncovered. Some have soldered them in place. You can remove the entire motor to get better access
Attached image(s) |
mmascari |
Apr 7 2018, 10:36 PM
Like this, not easy to see....the black plastic covers one, the second one is uncovered. Some have soldered them in place. You can remove the entire motor to get better access So did you have the same problem......headlights would not go down...and it was a solder issue on the motor? |
toolguy |
Apr 7 2018, 11:38 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Both headlights, doing the same thing. . I'd look at the green lead from the headlight switch which puts battery to the 'down' circuit. . most likely the switch
ClayPerrine |
Apr 8 2018, 07:07 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If it has been more than 4 hours seek medical help. (IMG:style_emoticons/default/lol-2.gif)
Seriously.... I have a diagram on how the headlights work. How your headlight motors work. If it is both headlights, it may be the headlight switch. |
jim_hoyland |
Apr 8 2018, 07:13 AM
Clay; Great diagrams. Where are the diodes ?
jim_hoyland |
Apr 8 2018, 07:17 AM
Like this, not easy to see....the black plastic covers one, the second one is uncovered. Some have soldered them in place. You can remove the entire motor to get better access So did you have the same problem......headlights would not go down...and it was a solder issue on the motor? One of the wires on my HL motor to a diode broke away. You can diagnose it if you have good access to the motor and those wires. I took a thin screwdriver and pushed the small wire onto the spot is was connected. Presto ! the motor came on and the bucket closed. If the diodes are still connected, then it's gonna be a different issue. |
mmascari |
Apr 8 2018, 10:02 AM
mmascari |
Apr 8 2018, 10:30 AM
I believe I found the problem...I checked the green wire on the drivers-side motor and as soon as I touched it, it broke off from the motor. Can I just solder it back on?
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:13 AM |
