| jim_hoyland |
Jun 14 2005, 06:35 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,132 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Clutch pedel just started to squeek when I push down ? No apparent friction.. just a squeek.
Is this a signal that somethig is wearng out ? Is there a simple solution ? any advice will be appreciated, |
| tat2dphreak |
Jun 14 2005, 06:39 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
sounds like the plastic bushings are giving up the ghost... replace with Brass... or if you are like me, lazy, don't have the tools, and afraid of F'in it up.. I got Eric's pedal cluster!!
| jim_hoyland |
Jun 14 2005, 06:41 PM
What is Eric's pedel cluster about ?
| redshift |
Jun 14 2005, 06:42 PM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Bronze.. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Pretty.. pretty cluster... about... I think it's $129... but that is probably 6, or 8 clicks from here... Look in the member's services thingy. M |
| jim_hoyland |
Jun 14 2005, 06:43 PM
Got a picture ?
| TimT |
Jun 14 2005, 06:45 PM
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
plastic bushings are shot
Eric does a nice rebuild job with a quick turn around.. and when you get the pedal cluster back you have bronze bushings where you used to have plastic |
| redshift |
Jun 14 2005, 06:46 PM
| tat2dphreak |
| aircooledboy |
Jun 14 2005, 06:47 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Are you sure it is coming from the pedal assembly and not the tunnel right next to it? Had the same thing, though it was the pedal, but AFTER BRAD and Andy gave me the free advice to check the source of the sound, it turned out to be my clutch tube breaking loose at the front weld. Quick spot weld, and good as new.
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
| jim_hoyland |
Jun 14 2005, 07:13 PM
What's the best way to see if its' the tube breaking loose ?
Lo-Fi Version | Time is now: 19th September 2026 - 10:32 AM |
